The MACsec Feature License provides IEEE 802.1AE link-level encryption and frame authentication. MACsec is a perpetual-only license and is not available as a subscription or trial license. MACsec must be purchased as a separate feature license using SKU PRD-EXOS-MACSEC.
MACsec is supported on the following ExtremeXOS platforms:
| Platform | Port Support | LRM/Adapter Required |
| X435 | All front-panel ports (except stacking ports) | No |
| X465 | All SFP/SFP+ ports and selected front-panel ports | Varies by port |
| X695 | All front-panel ports (except stacking ports) | No |
MACsec licensing behavior depends on switch type and license installation:
| Configuration | Without License | With License |
| Standalone Switch |
| Stacked Switches |
In a stacked configuration, any slot configured with a MACsec-capable module can be configured for MACsec, even if the slot is not physically present or does not have a valid MACsec license installed. However, MACsec can only be enabled on slots with a valid license.MACsec licensing requirements:
