- Create the VLAN.
- Create the Layer 2 I-SID.
- Map the customer VLAN to the I-SID.
- Optionally, if you associate the VLAN with a VRF (Layer 3 VSN), enable IP-VPN on that VRF and configure a CLIP interface in the VRF.
Configure the interface as a One IP interface, which means the gateway IP is the same as the VLAN IP. The gateway IP must be in different subnets for different interfaces, and must be the same on different routers for the same associated Layer 2 VSNs.
Configure a One IP interface on VLAN 11, assuming all necessary prerequisites are complete:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#interface vlan 11
Switch:1(config-if)#ip anycast-gateway one-ip 198.0.2.254/24
Switch:1(config-if)#ip anycast-gateway enable
Switch:1(config-if)#exit
Switch:1(config)#show vlan mac-address-entry 11
Vlan Fdb
VLAN MAC SMLT
ID STATUS ADDRESS INTERFACE REMOTE TUNNEL
11 self 00:00:5e:00:01:27 Port-mgmt false -
11 self d8:84:66:f6:dd:01 Port-cpp false -
c: customer vid u: untagged-traffic
2 out of 2 entries in all fdb(s) displayed.
Switch:1(config)#show i-sid mac-address-entry 11
I-SID Fdb Table
I-SID STATUS MAC-ADDRESS INTERFACE TYPE DEST-MAC BVLAN DEST-SYSNAME AREA-ROLE AREA-NAME
11 self 00:00:5e:00:01:27 Port-mgmt LOCAL 00:00:00:00:00:00 0 HOME area-49.0010
11 self d8:84:66:f6:dd:01 Port-cpp LOCAL 00:00:00:00:00:00 0 HOME area-49.0010
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense
l: discover by local switch r: discover by remote VIST switch
All 2 out of 2 Total Num of i-sid FDB Entries displayed
Switch:1(config)#show ip arp vlan 11
IP Arp - VRF testvrf
IP_ADDRESS MAC_ADDRESS VLAN PORT TYPE TTL(10 Sec) TUNNEL
198.0.2.254 d8:84:66:f6:dd:01 11 - LOCAL 2160
198.0.2.255 ff:ff:ff:ff:ff:ff 11 - LOCAL 2160
2 out of 2 ARP entries displayed
The following table defines parameters for the ip anycast-gateway one-ip command.
| Variable | Value |
| <0-511> | Specifies a number by which to offset the MAC address from the chassis MAC address. This ensures that each IP address has a different MAC address. If you omit this variable, a unique MAC offset is automatically generated. |
| A.B.C.D/X |
Specifies the gateway IPv4 address and subnet mask. The gateway IP must be in different subnets for different interfaces, and must be the same on different routers for the same associated Layer 2 VSNs. |
| enable | Enables Anycast IP Gateway on the VLAN. The default is disabled. |
| vrid <1-255> |
Specifies the gateway MAC as a VRRP MAC. The gateway MAC must be the same on different routers for the same associated Layer 2 VSN. If you do not specify the VRID as part of the command, the default value is VRID 39 (hexadecimal 27), which translates to the MAC of 00:00:5e:00:01:27. |
