- Create the VLAN.
- Configure an IP address for the VLAN.
- Create the Layer 2 I-SID.
- Map the customer VLAN to the I-SID.
- Optionally, if you associate the VLAN with a VRF (Layer 3 VSN), enable IP-VPN on that VRF.
Anycast IP Gateway routers advertise the configured routing interfaces, including the gateway MAC addresses and the gateway IP addresses. Associate the routing interfaces with Layer 2 VSNs, and configure each Anycast IP Gateway-enabled interface with a gateway IP and a gateway MAC.
Configure Anycast IP Gateway on VLAN 10, assuming all necessary prerequisites are complete:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#interface vlan 10
Switch:1(config-if)#ip anycast-gateway 192.0.2.254
Switch:1(config-if)#ip anycast-gateway enable
Switch:1(config-if)#exit
Switch:1(config)#show vlan mac-address-entry 10
Vlan Fdb
VLAN MAC SMLT
ID STATUS ADDRESS INTERFACE REMOTE TUNNEL
10 self 00:00:5e:00:01:27 Port-mgmt false -
10 self d8:84:66:f6:dd:01 Port-cpp false -
c: customer vid u: untagged-traffic
2 out of 2 entries in all fdb(s) displayed.
Switch:1(config)#show i-sid mac-address-entry 10
I-SID Fdb Table
I-SID STATUS MAC-ADDRESS INTERFACE TYPE DEST-MAC BVLAN DEST-SYSNAME AREA-ROLE AREA-NAME
10 self 00:00:5e:00:01:27 Port-mgmt LOCAL 00:00:00:00:00:00 0 HOME area-49.0010
10 self d8:84:66:f6:dd:01 Port-cpp LOCAL 00:00:00:00:00:00 0 HOME area-49.0010
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense
l: discover by local switch r: discover by remote VIST switch
All 2 out of 2 Total Num of i-sid FDB Entries displayed
Switch:1(config)#show ip arp vlan 10
IP Arp - GlobalRouter
IP_ADDRESS MAC_ADDRESS VLAN PORT TYPE TTL(10 Sec) TUNNEL
192.0.2.15 d8:84:66:f6:dd:01 10 - LOCAL 2160
192.0.2.254 00:00:5e:00:01:27 10 - LOCAL 2160
192.0.2.255 ff:ff:ff:ff:ff:ff 10 - LOCAL 2160
3 out of 3 ARP entries displayed
The following table defines parameters for the ip anycast-gateway command.
| Variable | Value |
| A.B.C.D |
Specifies the gateway IPv4 address. The gateway IP must be in different subnets for different interfaces, and must be the same on different routers for the same associated Layer 2 VSNs. You can configure a different gateway IP from the VLAN IP, or as a One IP interface to use the same IP as the VLAN. For more information, see Create a One IP Anycast IP Gateway Interface. |
| enable | Enables Anycast IP Gateway on the VLAN. The default is disabled. |
| vrid <1-255> |
Specifies the virtual router ID, which defines the gateway MAC as a VRRP MAC. The gateway MAC must be the same on different routers for the same associated Layer 2 VSN. If you do not specify the VRID as part of the command, the default value is VRID 39 (hexadecimal 27), which translates to the MAC of 00:00:5e:00:01:27. |
