Use this procedure to assign a nodal MEP to an SPBM B-VLAN. The Nodal MEP provides traceability and troubleshooting at the system level for a given B-VLAN. The Nodal B-VLAN MEPs created on the CP and function as if they are connected to the virtual interface of the given B-VLAN. Because of this they are supported for both port and MLT based B-VLANs.
Nodal MPs provide both MEP and MIP functionality for SPBM deployments. Nodal MPs are associated with a B-VLAN and are VLAN encapsulated packets. Each node (chassis) has a given MAC address and communicates with other nodes. The SPBM instance MAC address is used as the MAC address of the Nodal MP.
You must configure a CFM MD, MA, and MEP.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# vlan nodal-mep 100 md1 ma1 2
Switch:1(config)# show vlan nodal-mep
Vlan Nodal Mep
VLAN_ID DOMAIN_NAME.ASSOCIATION_NAME.MEP_ID
100 spbm.100.6
200 spbm.200.6
Switch:1(config)# vlan nodal-mip 100 6
Switch:1(config)# show vlan nodal-mip
Vlan Nodal Mip Level
VLAN_ID NODAL_MIP_LEVEL_LIST
1
100 6
216
304
41000
1001
The following table defines parameters for the vlan nodal-mep command.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID. |
WORD<0–22> |
The first parameter, specifies the Maintenance Domain name. |
WORD<0–22> |
The second parameter, specifies the Maintenance Association name. |
<1–8191> |
Specifies the nodal MEPs to add to the VLAN. |
The following table defines parameters for the vlan nodal-mip-level command.
Variable |
Value |
<1-4059> |
Adds the nodal MIP level. Specifies the VLAN ID. |
WORD<0–15> |
Adds the nodal MIP level, which has up to eight levels, ranging from 0 to 7. |
