Use this procedure to configure a DNS address for the DHCP Server to advertise to
clients.
- Select DHCP Server.
- Select the Global DNS tab.
- Select Insert.
- In IP address, type an IPv4 address for the DNS server.
- Select Insert.
Global DNS Field Descriptions
Use the data in the following table to use the Global DNS tab.
| Name | Description |
IP Address |
Specifies the IPv4 address of the DNS server. You can enter a maximum of eight DNS servers. |
Origin |
Specifies the origin of DHCP Server configuration, either manually configured through CLI or EDM, or dynamically configured through RADIUS. |
