Complete the following tasks to configure DHCP Server using EDM. Complete only the tasks that apply to your deployment.
| Step | Procedure | Description |
| 1 | Configure the DHCP Server Globally | Configure global values for the DHCP Server. |
| 2 | Configure a DNS Address for the DHCP Server | Configure DNS servers for the DHCP Server globally. |
| 3 | Configure an NTP Address for the DHCP Server | Configure NTP servers for the DHCP Server globally. |
| 4 | Configure Custom Option Definitions for the DHCP Server | Optional. Define Custom Options to assign non-standard DHCP parameters. |
| 5 | Configure Custom Option Data for DHCP Server Globally | Optional. Assign global data values for any custom options you configure. |
| 6 | Configure Vendor Options or a Vendor Class | Optional. Configure a vendor class and vendor options. |
| 7 | Create a DHCP Server Subnet | Create a DHCP subnet and assign an IP address pool to the subnet. |
| 8 | Configure Subnet Routers for DHCP Server | Optional. Assign IP addresses to subnet routers. |
| 9 | Configure DNS for a DHCP Server Subnet | Optional. Assign DNS servers for subnets. |
| 10 | Configure an NTP Server for a DHCP Server Subnet | Optional. Assign NTP servers for subnets. |
| 11 | Configure Custom Option Data for a DHCP Server Subnet | Optional. Assign subnet-specific data values for any custom options you configure. |
| 12 | Configure a Static DHCP Server Lease | Optional. Configure hosts for whom you want to reserve details, such as a specific IP address. |
| 13 | Enable DHCP Server | Enable the DHCP Server on the switch. |
| 14 | For High Availability, repeat the DHCP Server configuration on the peer switch. |
| Procedure | Description | |
1 |
Define DHCP Server vendor options definitions. |
2 |
Configure DHCP vendor option data global parameters. |
3 |
Configure a vendor class. |
4 |
Configure custom options data for the vendor class. |
5 |
Configure a value for the vendor option for the specified vendor class. |
