Use this procedure to configure subnet routers (default gateways) to advertise to
clients within a DHCP Server subnet.
- Select DHCP Server.
- Select the Subnet Routers tab.
- Select Insert.
- In Subnet IP, type the subnet network address.
- In Subnet Mask, type the subnet mask.
- In IP, type the router IPv4 address.
- Select Insert.
Subnet Routers Field Descriptions
Use the data in the following table to use the Subnet Routers tab.
| Name | Description |
Subnet IP |
Specifies the network address of the DHCP subnet. |
Subnet Mask |
Specifies the subnet mask for the DHCP subnet. |
IP |
Specifies the IPv4 address for the subnet router (default gateway). You can assign up to eight router addresses. |
