Perform this procedure to configure the remote Intermediate System-to-Intermediate System (IS-IS) manual area.
Configuring remote IS-IS manual area:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis remote Switch:1(config-isis-remote)#manual-area c1.1000.000.00
What to do next
To verify the configuration, see Display IS-IS Remote Area Configuration and Display IS-IS Area Configuration.
The following table defines parameters for the manual-area command.
| Variable | Value |
| <xx.xxxx.xxxx...xxxx> |
Specifies the remote IS-IS manual-area in the range of 1 to 13 bytes. |
