Static NSI OffsetNEW!
Beginning with this version, you can associate tagged VLANs to be mapped with a NSI value using static NSI offset configuration. When the NSI offset value is configured, any tagged VLAN that does not have a NSI associated will be applied with a NSI value, which is the sum of the configured NSI offset value and VLAN ID. The NSI offset applied to a VLAN will be removed if an NSI of higher precedence is applied to the VLAN.
Supported Platforms
All platforms.
New CLI Command
configure fabric attach [isid-nsi-offset [isid_nsi_offset | none]]
