You must use the detail parameter to display the egress port rate configuration and, if configured, the maximum burst size. Refer to Displaying Port Information for more information on the show ports information command.
# Module vlan configuration. # configure vlan Default tag 1 config port 3:1 rate-limit egress 128 Kbps max-burst-size 200 Kb config port 3:2 rate-limit egress 128 Kbps config port 3:10 rate-limit egress 73 Kbps max-burst-size 128 Kb configure vlan Default add ports 3:1-48 untagged
Refer to FDB for more information on limiting broadcast, multicast, or unknown MAC traffic ingressing the port.
