The following messages can appear during configuration of policies or rules for the SNMP service:
| Rule <rule> is already applied | A rule with the same name is already applied to this service. |
| Please remove the policy <policy> already configured, and then add rule <rule> | A policy file is already associated with the service. You must remove the policy before you can add a rule. |
| Rule <previous_rule> is not already applied | The specified rule has not been applied to the service, so you cannot add a rule in relation to that rule. |
| Rule <rule> is not applied | The specified rule has not been applied to the service, so you cannot remove the rule from the service. |
| Error: Please remove previously configured rule(s) before configuring policy <policy> | A policy or one or more ACL rules are configured for the service. You must delete the remove the policy or rules from the service before you can add a policy. |
