Base License Limits
The following table shows supported limits for features in the Base License.
Table 1. Supported Limits for the Base License
MetricProductLimit
AAA (local)—maximum number of admin and local user accounts.All platforms16
Access lists (meters)—maximum number of meters.4120, 5120512 ingress
128 egress
42202,048 ingress
256 egress
5320, 54206,144 ingress
512 egress
5320-16P-2MXT-2X1,024 ingress
256 egress
7520, 77201,024 ingress
2,000 egress
5520
2,048 ingress
512 egress
5720-MW6,144 ingress
3,072 egress
5720-MXW6,144 ingress
6,144 egress
Access lists (policies)—suggested maximum number of lines in a single policy file.All platforms300,000
Access lists (policies)—maximum number of rules in a single policy file. a 4220, 5320-48T/P, 7520, 77208,192 ingress
1,024 egress
5320-24T/P, 5320-16P8,192 ingress
512 egress
5320-16P-2MXT-2X
1,000 (rules double-wide (160-bit)) ingress
2,000 (rules single-wide (80-bit, default)) ingress
512 egress
4120, 51201,024 ingress
256 egress
5420M
18,000 (rules double-wide (160-bit)) ingress
36,000 (rules single-wide (80-bit, default)) ingress
1,024 egress
5420F
16,000 (rules single-wide (80-bit, default)) ingress
1,024 egress
5520
9,216 ingress
1,024 egress
5720-MW18,432 (80-bit) ingress
6,144 egress
5720-MXW
36,864 (80-bit), 18,432 (160-bit) ingress
12,288 egress
Access lists (policies)—maximum number of rules in a single policy file in first stage (VFP). 5520, 57202,048 ingress only
5320-48T/P, 5420, 7520, 77201,024 ingress only
4220, 5320-16P, 5320-24T-4X-XT512 ingress only
4120, 5120256 ingress
Access lists (slices)—number of ACL slices. 5720, 7520, 772012 ingress
4 egress
5320-48T/P, 5420, 552018 ingress
4 egress
4120, 4220, 5120, 5320-24T/P, 5320-16P 8 ingress
4 egress
Access lists (slices)—number of ACL slices in first stage (VFP).All platforms4 ingress only
ACL Per Port Meters—number of meters supported per port.All platforms16
ACL port ranges.All platforms32
Meters Packets-Per-Second Capable.All platformsN/A
AVB (audio video bridging)—maximum number of active streams. 5320, 54201,024
5520, 5720, 75204,096
BFD sessions (Software Mode)—maximum number of BFD sessions. 5320, 5420, 5520, 5720, 7520, 7720 (default timers—1 sec). 512
5120 (default timers—1 sec).90
BFD IPv4 sessions (Hardware Assisted)—maximum number of IPv4 BFD sessions. 7520, 7720900
425
256 (with 3 ms transmit interval)
BFD IPv6 sessions (Hardware Assisted)—maximum number of IPv6 BFD sessions. 7520, 7720425 (PTP not enabled)
BGP (multicast address-family routes)—maximum number of multicast address-family routes.5520, 5720-MXW13,000
5720-MW20,000
7520, 772025,000
5320-16P-4XE, 5320 24-port except XT8,000
5320 48-port, 542012,000
5320-24T-4X-XT, 5320-16P-2MXT-2X992
512064
BGP (non-unique routes)— maximum number of nonunique BGP routes.7520. 772075,000
5720-MW60,000
5320 48-port, 542036,000
5320-16P-4XE, 5320 24-port except XT24,000
5320-24T-4X-XT, 5320-16P-2MXT-2X2,700
5120 192
BGP (peers)—maximum number of BGP peers. All platforms except 4120 and 42202
BGP (unicast address-family routes)—maximum number of unicast address-family routes.5520, 5720-MW (at default)13,000
5720-MXW (at default)20,000
7520, 7720 (at deafult)25,000
5320 48-port, 5420 12,000
5120 64
5720-MW (with ALPM enabled)163,000
5720-MXW (with ALPM enabled)288,000
5520 (with ALPM enabled)80,000
BGP auto-peering—maximum number of auto-peering nodes and VTEPs.All platforms except 4120 and 422064
BGP auto-peering attached IPv4 hosts— maximum number of attached IPv4 hosts.All platforms except 4120 and 422064,000
BGP auto-peering attached IPv6 hosts— maximum number of attached IPv6 hosts.All platforms except 4120 and 42208,000
BGP auto-peering ECMP—maximum number of equal cost multipath for auto-peering.
Note: * Subject to the limitation imposed by the number of physical ports on a switch.
5720, 7520, 772016*
5320, 5420, 55204*
BGP auto-peering maximum IPv4 prefixes with ECMP—Maximum number of IPv4 Network prefixes with ECMP. 5120, 5320, 5420, 5520, 572016,000
7520, 772064,000
BGP auto-peering maximum IPv6 prefixes with ECMP—Maximum number of IPv6 Network prefixes with ECMP. 5120, 5320, 5420, 5520, 5720254
7520, 772064,000
BGP auto-peering MLAG peers—maximum MLAG peers per AutoBGP node.All platforms except 4120 and 42201
BGP auto-peering VRFs—maximum number of VRFs.All platforms except 4120 and 422064
BGP auto-peering EVPN instances—maximum EVPN instances.All platforms except 4120, 4220, and 51201,024
BGPv6 (unicast address family routes)—maximum number of unicast address family routes.5320 48-port, 5420, 5520, 5720-MW (at default)6,000
5720-MW (with ALPM enabled)107,000
5720-MXW, 7520, 7720 (at default)10,000
512064
5720-MXW (with ALPM enabled)213,000
5520 (with ALPM enabled)40,000
5320-16P-4XE, 5320 24-port except XT4,000
5320-24T-4X-XT, 5320-16P-2MXT-2X496
BGPv6 (non-unique routes)— maximum number of nonunique BGP routes.5320 48-port, 5420, 5520, 5720-MW18,000
5720-MXW, 7520, 772030,000
5320-24T-4X-XT, 5320-16P-2MXT-2X14,000
5320-16P-4XE, 5320 24-port except XT 12,000
512064
BOOTP/DHCP relay—maximum number of BOOTP or DHCP servers per virtual router.All platforms8
BOOTP/DHCP relay—maximum number of BOOTP or DHCP servers per VLAN.All platforms8
BOOTP/DHCP relay—maximum number of DHCPv4/v6 relay agentsAll platforms4,000
Connectivity fault management (CFM)—maximum number or CFM domains. All platforms8
CFM—maximum number of CFM associations. All platforms256
CFM—maximum number of CFM up end points. All platforms32
CFM—maximum number of CFM down end points. All platforms32
CFM—maximum number of CFM remote end points per up/down end point. All platforms2,000
CFM—maximum number of dot1ag ports. All platforms128
CFM—maximum number of CFM segments. All platforms1,000
CFM—maximum number of MIPs. All platforms256
CLEAR-Flow—total number of rules supported. The ACL rules plus CLEAR-Flow rules must be less than the total number of supported ACLs.4120, 4220, 5120, 5320, 5420, 5720, 7520, 77208,192
ExtremeSwitching 55209,215
Data Center Bridging eXchange (DCBX) protocol Type Length Value (TLVs)—maximum number of DCBX application TLVs.All platforms8
DHCPv6 Prefix Delegation Snooping—Maximum number of DHCPv6 prefix delegation snooped entries.All platforms256 (with underlying protocol RIPng)
128 (with underlying protocol OSPFv3)
1,024 (with static routes)
DHCP snooping entries—maximum number of DHCP snooping entries.All platforms2,048
Dynamic ACLs—maximum number of ACLs processed per second.
Note: Limits are load-dependent.
All platforms
  • with 50 DACLs
  • with 500 DACLs
  • 10
  • 5
EAPS domains—maximum number of EAPS domains.
Note: An EAPS ring that is being spatially reused cannot have more than four configured EAPS domains.
5720128
4120, 4220, 5120, 5320-24T/P, 5320-16P32
5320-48T/P, 5420, 552064
EAPSv1 protected VLANs—maximum number of protected VLANs. 4120, 4220, 5120, 5320-24T/P, 5320-16P1,000
5320-48T/P, 5420, 5520, 5720, 7520, 77202,000
EAPSv2 protected VLANs—maximum number of protected VLANs. 4120, 4220, 5120, 5320, 5420, 55201,000
ELSM (vlan-ports)—maximum number of VLAN ports.4120, 4220, 5120, 5320-24T/P, 5320-16P4,000
5320-48T/P, 5420, 5520, 5720, 7520, 77205,000
ERPS domains—maximum number of ERPS domains with or without CFM configured.All platforms32
ERPSv1 protected VLANs—maximum number of protected VLANs. 4120, 4220, 5120, 5320-24T/P, 5320-16P1,000
ERPSv2 protected VLANs—maximum number of protected VLANs. 4120, 4220, 5120, 5320-24T/P, 5320-16P500
ESRP groups—maximum number of ESRP groupsAll platforms32
ESRP domains—maximum number of ESRP domains. 4220, 5320, 5420, 5520, 5720, 7520, 7720.64
4120, 512032
ESRP L2 VLANs—maximum number of ESRP VLANs without an IP address configured. 4220, 5320, 5420, 5520, 5720, 7520, 77201,000
4120, 5120120
ESRP L3 VLANs—maximum number of ESRP VLANs with an IP address configured. 5320-48T/P, 5420, 5520, 5720, 7520, 7720511
4220, 5320-24T/P, 5320-16P509
4120, 5120120
ESRP (maximum ping tracks)—maximum number of ping tracks per VLAN.All platforms8
ESRP (IP route tracks)—maximum IP route tracks per VLAN.All platforms8
ESRP (VLAN tracks)—maximum number of VLAN tracks per VLAN.All platforms1
Extended Edge Switching maximum BPEs—maximum number of attached bridge port extenders (BPEs). 5520, 7520-48Y48
542020
Extended Edge Switching maximum cascade ports—maximum number of upstream ports on bridge port extenders (BPEs). 5420, 5520, 7520-48Y
2 on V400-24 and V300 models
4 on V400-48 models
Extended Edge Switching maximum tiers—maximum number of cascade levels (tiers) of bridge port extenders (BPEs).ExtremeSwitching 5420, 5520, 7520-48Y4
(except for V300-8P-2T-W, which support 1 tier)
Extended Edge Switching maximum ring BPEs—maximum number of bridge port extenders (BPEs) in a ring topology.ExtremeSwitching 5420, 5520, 7520-48Y8
Extended Edge Switching maximum VLANs—maximum number of VLANs - Includes all VLANsExtremeSwitching 5520, 7520-48Y4,094
ExtremeSwitching 54201,024
Extended Edge Switching VLAN+ port memberships—maximum number of VLAN+ (extended) port memberships.ExtremeSwitching 5520, 7520-48Y
12,000 in hash mode (default)
131,000 in port-group mode
5420
8,750 in hash mode (default)
131,617 in port-group mode
Forwarding rate—maximum L3 software forwarding rate.42209,274 pps
412012,624 pps
51209,000 pps
5320-24P-8XE, 5320-24T-4X-XT11,000 pps
5320-48P19,142 pps
5420F21,585 pps
552018,838 pps
5720-MW27,000 pps
5720-MXW31,000 pps
7520, 772034,813 pps
FDB (unicast blackhole entries)—maximum number of unicast blackhole FDB entries.4120, 512016,384
4220, 532032,000
ExtremeSwitching 5420M65,536
ExtremeSwitching 5420F32,768 f
ExtremeSwitching 5520114,688 f
ExtremeSwitching 5720-MW163,840 f
ExtremeSwitching 5720-MXW, 7520, 7720294,912 f
FDB (multicast blackhole entries)—maximum number of multicast blackhole FDB entries. 5520, 5720-MW4,096
4120, 4220, 5120, 5320, 54201,024
5720-MXW, 7520, 772016,000
FDB (maximum L2 entries)—maximum number of MAC addresses.4120, 512016,384
4220, ExtremeSwitching 532032,000
ExtremeSwitching 5420F32,768 g
ExtremeSwitching 5520114,688 g
ExtremeSwitching 5720-MW163,840 g
5720-MXW, 7520, 7720294,912 g
FDB (maximum L2 entries)—maximum number of multicast FDB entries.ExtremeSwitching 55204,096
5720, 7520, 772016,000
GRE Tunnels—maximum number of GRE tunnels.All platforms, except 4120, 5120255
Identity management—maximum number of Blacklist entries.All platforms except 4120 and 4220.512
Identity management—maximum number of Whitelist entries.All platforms except 4120 and 4220.512
Identity management—maximum number of roles that can be created.All platforms except 4120 and 4220.64
Identity management—maximum role hierarchy depth allowed. All platforms except 4120 and 4220.5
Identity management—maximum number of attribute value pairs in a role match criteria. All platforms except 4120 and 4220.16
Identity management—maximum number of child roles for a role.All platforms except 4120 and 4220.8
Identity management—maximum number of policies/dynamic ACLs that can be configured per role.All platforms except 4120 and 4220.8
Identity management—maximum number of LDAP servers that can be configured.All platforms except 4120 and 4220.8
Identity management—maximum number of Kerberos servers that can be configured.All platforms except 4120 and 4220.20
Identity management—maximum database memory size.All platforms except 4120 and 4220.512
Identity management—recommended number of identities per switch.
Note: Number of identities per switch is for a default identity management database size (512 Kbytes) across all platforms.
All platforms except 4120 and 4220.100
Identity management—recommended number of ACL entries per identity.
Note: Number of ACLs per identity, based on system ACL limitation.
Identity management—maximum number of dynamic ACL entries configured as an individual dynamic rule, or as an ACL entry in a policy file.All platforms except 4120 and 4220.500
IGMP snooping per VLAN filters—maximum number of VLANs supported in per-VLAN IGMP snooping mode.ExtremeSwitching 5320 (except 5320-24T-4X-XT), 5420, 5520, 5720, 7520, 77201,500
4220, ExtremeSwitching 5320-24T-4X-XT 500
412048
5120100
IGMPv1/v2 SSM-map entries—maximum number of IGMPv1/v2 SSM mapping entries.5320, 5420, 5520, 5720, 7520, 77206
512060
IGMPv1/v2 SSM-map entries—maximum number of sources per group in IGMPv1/v2 SSM mapping entries.All platforms except 4120 and 4220.50
IGMPv2 subscriber—maximum number of IGMPv2 subscribers per port. n5320 (except 5320-24T-4X-XT), 5420, 7520, 7720 ,5720,55204,000
4220, 5320-24T-4X-XT1,000
4120, 5120250
IGMPv2 subscriber—maximum number of IGMPv2 subscribers per switch.nExtremeSwitching 5320 (except 5320-24T-4X-XT), 5420, 552020,000
ExtremeSwitching 5720-MW, 7520, 772045,000
ExtremeSwitching 5720-MXW54,000
4120, 5120256
IGMPv3 maximum source per group—maximum number of source addresses per group.All platforms250
IGMPv3 subscriber—maximum number of IGMPv3 subscribers per port. n 5320 (except 5320-24T-4X-XT), 5420, 5520, 5720, 7520, 77204,000
1,000
4120, 5120250
IGMPv3 subscriber—maximum number of IGMPv3 subscribers per switch. nExtremeSwitching 5320 (except 5320-24T-4X-XT), 5420, 552020,000
4120, 5120256
IP ARP entries in software—maximum number of IP ARP entries in software.
Note: Might be limited by hardware capacity of FDB (maximum L2 entries).
4120, 5120400
4220, 5320-16P-2MXT-2X4,000
5320 (except 5320-16P-2MXT-2X), 5420F models12,000
5420M models24,000
552074,750 h
5720-MW100,000
7520, 7720184,318 (up to)
ExtremeSwitching 5720-MXW221,000
IPv4 ARP entries in hardware with minimum LPM routes—maximum recommended number of IPv4 ARP entries in hardware, with minimum LPM routes present. Assumes number of IP route reserved entries is 100 or less.4120, 5120397
42204,000
532012,000
ExtremeSwitching 5420M models24,000
ExtremeSwitching 5420F models12,000
ExtremeSwitching 552060,000 h
ExtremeSwitching 5720-MW80,000 h
7520, 7720146,000 h
ExtremeSwitching 5720-MXW172,000 h
IPv4 ARP entries in hardware with maximum LPM routes—maximum recommended number of IPv4 ARP entries in hardware, with maximum LPM routes present. Assumes number of IP route reserved entries is “maximum.”4120, 5120384
42203,000
532010,000
5320-16P-2MXT-2X3,000
ExtremeSwitching 5420M models21,000
ExtremeSwitching 5420F models10,000
ExtremeSwitching 552049,000 h
ExtremeSwitching 5720-MW70,000 h
7520, 7720125,000 h
ExtremeSwitching 5720-MXW156,000 h
IP flow information export (IPFIX)—number of simultaneous flows.ExtremeSwitching 54204,000 (IPv4 and IPv6 flows)
ExtremeSwitching 552032,000 (IPv4 flows)
18,000 (IPv6 flows)
ExtremeSwitching 5720257,000 (IPv4 flows)
112,000 (IPv6 flows)
IPv4 remote hosts in hardware with zero LPM routes—maximum recommended number of IPv4 remote hosts (hosts reachable through a gateway) in hardware when LPM routing is not used. Assumes number of IP route reserved entries is 0, and number of IPv4 ARP entries present is 100 or less.4120, 5120450
42204,000
532020,000
5320-16P-2MXT-2X7,000
ExtremeSwitching 5320-24T/P, 5320-16P24,000
ExtremeSwitching 5420M36,000
ExtremeSwitching 5420F24,000 h
ExtremeSwitching 5520102,000 h
ExtremeSwitching 5720-MW139,000 h
7520, 7720241,000 (up to)
5720-MXW (with ALPM enabled)245,000 h
IPv4 routes—maximum number of IPv4 routes in software (combination of unicast and multicast routes), including static and from all routing protocols. 552081,000
4120, 4220, 5120, 5320, 542025,000
5720-MW 163,000
5720-MXW288,000
7520, 7720350,000
IPv4 routes (LPM entries in hardware)— number of IPv4 routes in hardware.4120, 512064 q
4220, 5320-16P-2MXT-2X992
5320-16T/P, 5320-24T/P8,000
5320-48T/P, 542012,000
552081,000 q
ExtremeSwitching 5720-MW163,000 q
7520, 7720262,000 up to 350,000 q
ExtremeSwitching 5720-MXW288,000 q
IPv6 6in4 tunnel—maximum number of IPv6 6in4 tunnels.All platforms except 4120, 5120255
IPv6 6to4 tunnel—maximum number of IPv6 6to4 tunnels.All platforms except 4120, 51201 (per virtual router)
IPv6 addresses on an interface—maximum number of IPv6 addresses on an interface.All platforms255
IPv6 addresses on a switch—maximum number of IPv6 addresses on a switch.All platforms 2,048
IPv6 host entries in hardware—maximum number of IPv6 neighbor entries in hardware.4120, 5120200
42202,000
53206,000
5420M models12,000
ExtremeSwitching 5420F models6,000
ExtremeSwitching 552018,000 s
ExtremeSwitching 5720-MW24,000 s
7520, 772057,000 h
ExtremeSwitching 5720-MXW78,000 s
IPv6 routes in software—maximum number of IPv6 routes in software, including static routes and routes from all routing protocols.ExtremeSwitching 552018,000 q
4120, 4220, 5320, 542025,000
5720-MW70,000 q
7520, 7720196,000 q
ExtremeSwitching 5720-MXW213,000 q
IPv6 routes (LPM entries in hardware)—maximum number of IPv6 routes in hardware.4120, 512064 q
4220512
ExtremeSwitching 552040,000 q
ExtremeSwitching 54206,000
ExtremeSwitching 5720-MW107,000 q
7520, 7720131,000 up to 196,000 q
5720-MXW213,000 q
IPv6 routes with a mask greater than 64 bits in hardware—maximum number of such IPv6 LPM routes in hardware. 5320, 5420256
4220, 5520, 7520, 77208,192 r
32,000 r
5720-MW16,000 r
5720-MXW24,000 r
IPv6 route sharing in hardware—route mask lengths for which ECMP is supported in hardware.4120, 4220, 5120, 5320, 5420
0–64, >64 single path only
0–128 r
IP router interfaces—maximum number of VLANs performing IPv4 and/or IPv6 routing. Excludes sub-VLANs. 4120, 5120126
5320-48T/P, 54201,533
5320-16P-2MXT-2X1,021
5520, 5720, 7520, 77202,048
IP multicast static routes—maximum number of permanent multicast IP routes.All platforms1,024
IP unicast static routes—maximum number of permanent IP unicast routes.All platforms1,024
IP route sharing (maximum gateways)—Configurable maximum number of gateways used by equal cost multipath OSPF, BGP, IS-IS, static routes, or L2VPNs. Static routes, OSPF, and BGP are limited to 64 ECMP gateways per destination, while IS-IS is limited to 8. L2VPNs are limited to 16 LSPs per pseudowire on platforms that support 32 gateways, and 64 LSPs per pseudowire on platforms that support 64 gateways.4120, 4220, 5120, 5320, 5420, 55202, 4, or 8
5720, 7520, 77202, 4, 8, 16, 32, or 64
IP route sharing (total combinations of gateway sets)—maximum number of combinations of sets of adjacent gateways used by multipath OSPF, BGP, IS-IS, or static routes.4120, 512062 (if maximum gateways is 2, 4, or 8)
4220, 5320
Note: The values here represent the maximum attainable ECMP groups of which, due to the RIOT feature, half are reserved for overlay and half for underlay routing.
124 (if maximum gateways is 2)
124 (if maximum gateways is 4)
60 (if maximum gateways is 8)
5420
510 (if maximum gateways is 2)
254 (if maximum gateway is 4)
126 (if maximum gateways is 8)
5520
2,046 (if maximum gateways is 2)
1,022 (if maximum gateway is 4)
510 (if maximum gateways is 8)
5720
  • if maximum gateways is 2
  • if maximum gateways is 4
  • if maximum gateways is 8
  • if maximum gateways is 16 (default)
  • if maximum gateways is 32
  • if maximum gateways is 64
  • 2,046
  • 2,046
  • 2,046
  • 1,022
  • 510
  • 254
7520, 7720
  • 4,094
  • 4,094
  • 2,046
  • 1,022
  • 510
  • 254
IP multinetting (secondary IP addresses)—maximum number of secondary IP addresses per VLAN.All platforms255
Jumbo frames—maximum size supported for jumbo frames, including the CRC.All platforms9,216
Layer-2 IPMC forwarding caches—(IGMP/MLD/PIM snooping) in mac-vlan mode.
Note:
  • The internal lookup table configuration used is "l2-and-l3”.
  • IPv6 and IPv4 L2 IPMC scaling is the same for this mode.
  • Layer-2 IPMC forwarding cache limits—(IGMP/MLD/PIM snooping) in mixed-mode are the same.
4120 and 4220 do not support PIM snooping.
4120, 5120192
4220, 532032,000
542064,000
552032,768
5720-MW49,152
7520, 772073,000
5720-MXW81,920
Layer-3 IPv4 Multicast—maximum number of <S,G,V> entries installed in the hardware (IP multicast compression enabled).
Note:
  • Limit value is the same for MVR senders, PIM Snooping entries. PIM SSM cache, IGMP senders, PIM cache.
  • Assumes source-group-vlan mode as look up key.
  • Layer 3 IPMC cache limit in mixed mode also has the same value.
4120, 5120192
42202,000
5320 (except 5320-24T-4X-XT)8,000
ExtremeSwitching 5420M12,000
ExtremeSwitching 5420F6,000
552043,000
ExtremeSwitching 5720-MW61,000
7520, 7720104,000
ExtremeSwitching 5720-MXW110,000
ExtremeSwitching 5320-24T-4X-XT2000
Layer-3 IPv6 Multicast—maximum number of <S,G,V> entries installed in the hardware (IP multicast compression enabled). 4120, 5120100
Note:
  • Limit value is the same for MLD sender per switch, PIM IPv6 cache.
  • Assumes source-group-vlan mode as lookup key.
42201,000
4120 and 4220 do not support PIM snooping, but MLD cache is supported in the hardware.
ExtremeSwitching 5320 (except 5320-24T-4X-XT)4,000
ExtremeSwitching 5420M6,000
ExtremeSwitching 5420F3,000
ExtremeSwitching 552021,500
ExtremeSwitching 5720-MW30,500
7520, 772052,000
ExtremeSwitching 5720-MXW55,000
ExtremeSwitching 5320-24T-4X-XT1,000
Load sharing—maximum number of load sharing groups.
Note: The actual number of load-sharing groups that can be configured is limited by the number of physical ports present in the switch or SummitStack.
All platforms128
Load sharing—maximum number of ports per load-sharing group. For standalone and stacked: 4120, 4220, 5120, 5320, 54208
For standalone: ExtremeSwitching 5520, 5720, 7520, 772032
For stacked: ExtremeSwitching 5520, 5720, 7520, 772064
Logged messages—maximum number of messages logged locally on the system.All platforms20,000
MAC-based security—maximum number of MAC-based security policies.All platforms1,024
MAC Locking—Maximum number of MAC locking stations that can be learned on a port.All platforms
64 (static MAC locking stations)
600 (first arrival MAC locking stations)
Meters—maximum number of meters supported.All platforms2,048
Maximum mirroring instances.All platforms except 4120 and 51204 total, 2 egress
4120, 51206 defined, max 4 enabled (max 1 egress)
Mirroring (filters)—maximum number of mirroring filters.
Note: This is the number of filters across all the active mirroring instances.
All platforms128
Mirroring, one-to-many (filters)—maximum number of one-to-many mirroring filters.
All platforms128
Mirroring, one-to-many (monitor port)—maximum number of one-to-many monitor ports.All platforms16
MLAG ports—maximum number of MLAG ports allowed.
Note: The number of MLAG ports that can be configured is limited by the number of physical ports present in the system.
5120, 532055
572063
4120, 4220
5420, 552059
7520, 7720 61
MLAG peers—maximum number of MLAG peers allowed.All platforms2
Multicast listener discovery (MLD) snooping per-VLAN filters—maximum number of VLANs supported in per-VLAN MLD snooping mode. 5320 (except 5320-24T-4X-XT), 5420, 5520, 5720, 7520, 77201,500
4220, 5320-24T-4X-XT250
4120, 512032
Multicast listener discovery (MLD)v1 subscribers—maximum number of MLDv1 subscribers per port. n 5320 (except 5320-24T-4X-XT), 5420, 5520, 5720, 7520, 77204,000
4120, 5120100
Multicast listener discovery (MLD)v1 subscribers—maximum number of MLDv1 subscribers per switch. nExtremeSwitching 5320 (except 5320-24T-4X-XT), 5420, 5520 10,000
ExtremeSwitching 5720-MW30,000
7520, 772045,000
4120, 5120100
Multicast listener discovery (MLD)v2 subscribers—maximum number of MLDv2 subscribers per port. nExtremeSwitching 5320 (except 5320-24T-4X-XT), 5420, 5520, 5720, 7520, 77204,000
4220, ExtremeSwitching 5320-24T-4X-XT1,000
4120, 5120100
Multicast listener discovery (MLD)v2 subscribers—maximum number of MLDv2 subscribers per switch. n4120, 4220, 5320 (except 5320-24T-4X-XT), 5420, 552010,000
7520, 772045,000
4120, 5120100
Multicast listener discovery (MLD)v2 maximum source per group—maximum number of source addresses per group.All platforms except 4120, 5120200
4120, 5120100
Multicast listener discovery (MLD) SSM-map entries—maximum number of MLD SSM mapping entries.5320, 5420, 5520, 5720, 7520, 7720500
Multicast listener discovery (MLD) SSM-MAP entries—maximum number of sources per group in MLD SSM mapping entries.5120, 5320, 5420, 5520, 5720, 7520, 772050
Network Address Translation (NAT) VLANs—maximum number of NAT VLANs.7520, 77204
Network Address Translation (NAT) Sessions—number of NAT sessions supported (non twice-NAT).7520, 77201,023
Network Login—maximum number of clients being authenticated on MAC-based VLAN enabled ports.All platforms1,024
Network Login—maximum number of dynamic VLANs.All platforms1,024
Network Login VLAN VSAs—maximum number of VLANs a client can be authenticated on at any given time.All platforms10
Network Service Identifiers (NSI)/VLAN mappings—maximum number of VLANs to NSI mappings.All platforms94
Node Alias—maximum number of entries per slot.All platforms8,192
ONEPolicy Dynamic ACL Rules—maximum number of Dynamic ACLs supported via RADIUS VSA 232 per user in Access-List mode.All platforms64
ONEPolicy Roles/Profiles—maximum number of policy roles/profiles.All platforms63
ONEPolicy Rules per Role/Profile—maximum number of rules per role/policy. 5320-24T-4X-XT
IPv4 Rules: 256
IPv6 Rules: 0
MAC Rules: 0
L2 Rules: 184
4120, 5120IPv4:128
L2:56
4220IPv4:256
L2:184
5320
IPv4 Rules: 1,024
IPv6 Rules: 0
MAC Rules: 0
L2 Rules: 952
ExtremeSwitching 5420-F, 5320-24T-24S-4XE-XT 7520, 7720
IPv4 Rules: 512
IPv6 Rules: 512
MAC Rules: 512
L2 Rules: 440
IPv4 Rules: 1,536
IPv6 Rules: 1,536
MAC Rules: 1,536
L2 Rules: 1,464
IPv4 Rules: 2,048
IPv6 Rules: 2,048
MAC Rules: 2,048
L2 Rules: 1 ,976
ExtremeSwitching 5420-M, 5520
IPv4 Rules: 1,024
IPv6 Rules: 1,024
MAC Rules: 1,024
L2 Rules: 952
ONEPolicy Authenticated Users per Switch—maximum number of authenticated users per switch only with TCI-Overwrite enabled.ExtremeSwitching 5520, 57201,024
ExtremeSwitching 5320-24T-4X-XT128
ExtremeSwitching 5320, 5420, 7520, 7720512
4120, 4220, 5120256
StackingDepends on the stack nodes, but the maximum is 1,024.
ONEPolicy Authenticated Users per Switch—maximum number of authenticated users per switch with TCI-Overwrite disabled.
Note: The maximum values assume 75% utilization of VLAN-XLATE hash table.
Stacking1,536–65,534
7520, 772024,576
ExtremeSwitching 5320-24T-4X-XT384
4120, 4220, ExtremeSwitching 5120, 5320, 5420768
ExtremeSwitching 572012,288
ExtremeSwitching 55209,216
ONEPolicy Authenticated Users per Port per Switch— maximum number of authenticated users per port per switch with TCI overwrite disabled.
4120, 4220, 5120, 5320, 5420768
7520, 772024,576
ONEPolicy Authenticated Users per Port per Switch— maximum number of authenticated users per port with only with TCI-Overwrite enabled.4120, 5120256
4220440
5120, 5320, 5420, 7520, 7720512
5520, 57201,024
ONEPolicy Permit/Deny Traffic Classification Rules Types—total maximum number of unique permit/deny traffic classification rules types (system/stack). 5320, 5420-F, 7520, 77201,976
5720-MW6,072
5720-MXW8,120
5420-M, 55204,024
5320-24T-24S-4XE-XT512
4220440
4120, 5120184
5320-24T-4X-XT128
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique MAC permit/deny traffic classification rules types (macsource/macdest). 5420-M, 55201,024
5420-F, 5320-24T-24S-4XE-XT 7520, 7720512
5720-MW1,536
5720-MXW2,048
4120, 4220, 5120, 5320N/A
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique IPv6 permit/deny traffic classification rules types (ipv6dest).ExtremeSwitching 5420-M. 55201,024
ExtremeSwitching 5420-F, 5320-24T-24S-4XE-XT 7520, 7720512
ExtremeSwitching 5720-MW1,536
ExtremeSwitching 5720-MXW2,048
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique IPv4 permit/deny traffic classification rules (typesipsource / ipdest / ipfrag / udpsourceportIP / udpdestportIP / tcpsourceportIP / tcpdestportIP / ipttl / iptos / iptype).ExtremeSwitching 5320-24T-4X-XT256
5120, 5320, 5420-F, 55201,024
ExtremeSwitching 5420-M, 5320-24T-24S-4XE-XT 7520, 7720512
4220256
4120, 5120128
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique Layer 2 permit/deny traffic classification rules (ethertype/port).ExtremeSwitching 5320-24T-24S-4XE-XT440
ExtremeSwitching 5320, 5420-M, 5520952
5720-MW1,464
5720-MXW1,976
5420-F, 7520, 7720440
4220, 5320-24T-4X-XT184
4120, 512056
OnePolicy Maximum number of rules supported in AccessList mode—maximum number of rules in AcessList mode. 7520, 77203,512
4120, 5120440
4220, 5320-24T-4X-XT952
5320, 5420-F, 5320-24T-24S-4XE-XT4,024
5420-M8,120
5720-MW12,216
5720-MXW16,312
OSPFv2/v3 ECMP—maximum number of equal cost multipath OSPFv2 and OSPFv3. 4120, 4220, 5120, 5320, 5420, 5520, 57208
7520, 772064
OSPFv2 areas—as an ABR, how many OSPF areas are supported within the same switch.All platforms8
OSPFv2 external routes—recommended maximum number of external routes contained in an OSPF LSDB. 55205,000
5720, 7520, 772010,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 54204,000
5320-16P-2MXT-2X992
4220, 5320-24T-4X-XT500
4120, 512064
OSPFv2 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes contained in an OSPF LSDB with one ABR in OSPF domain. 5520, 5720-MXW, 7520, 77202,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 54201,600
5320-16P-2MXT-2X992
4120, 512064
OSPFv2 inter-vr or leaking routes—recommended maximum number of inter-vr routes contained in an OSPF LSDB.​​​ 5420, 5520, 5720, 7520, 77202,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT)1,600
4120, 512064
OSPFv2 interfaces—recommended maximum number of OSPF interfaces on a switch (active interfaces only).All platforms4
OSPFv2 links—maximum number of links in the router LSA. 4120, 5320, 5420, 5520, 5720, 7520, 7720400
4220, 512064
OSPFv2 neighbors—maximum number of supported OSPF adjacencies.All platforms4
OSPFv2 routers in a single area—recommended maximum number of routers in a single OSPF area. 552050
5720, 7520, 7720100
4120, 4220, 5120, 5320, 542040
OSPFv2 virtual links—maximum number of supported OSPF virtual links. All platforms32
OSPFv3 areas—as an ABR, the maximum number of supported OSPFv3 areas. 552016
5720, 7520, 7720100
5120, 5320, 542012
OSPFv3 external routes—recommended maximum number of external routes. 5520, 5720-MXW, 7520, 772010,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 5720-MW7,500
54206,000
5320-24T-4X-XT300
5320-16P-2MXT-2X496
512064
OSPFv3 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes. 55203,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 5720, 7520, 77204,000
5420 6,000
5320-24T-4X-XT300
5320-16P-2MXT-2X496
512064
OSPFv3 interfaces—maximum number of OSPFv3 interfaces (active interfaces only).All platforms except 4120 and 42204
OSPFv3 neighbors—maximum number of OSPFv3 neighbors.All platforms except 4120 and 42204
OSPFv3 virtual links—maximum number of OSPFv3 virtual links supported. All platforms except 4120 and 422016
PIM IPv4 Limits—maximum number of multicast groups per dynamic rendezvous point. 512032
PIM IPv4 Limits—maximum number of multicast groups per static rendezvous point. All platforms, except 4120 and 5120180
4120, 512032
PIM IPv4 Limits—maximum number of multicast sources per group.All platforms except 4120, 4220, 51205,000
4220, 5320-24T-XT2,000
4120, 5120192
PIM IPv4 Limits—maximum number of dynamic rendezvous points per multicast group.All platforms145
PIM IPv4 Limits—static rendezvous points.All platforms32
PIM IPv6 (maximum interfaces)—maximum number of PIM active interfaces.All platformsN/A
PIM IPv6 Limits—maximum number of multicast sources per group.All platforms except 4120, 4220, 51201,750
4220, 5320-24T-XT1,000
4120, 512070
PIM IPv6 Limits—maximum number of multicast groups per dynamic rendezvous point.All platforms except 4120 and 422070
PIM IPv6 Limits—maximum number of multicast groups per static rendezvous point.All platforms except 4120 and 5120
3,000 (depends on policy file limits)
4120, 512070
PIM IPv6 Limits—maximum number of dynamic rendezvous points per multicast group.All platforms64
PIM IPv6 Limits—maximum number of secondary addresses per interface.All platforms70
PIM IPv6 Limits—static rendezvous points.All platforms32
Policy-based routing (PBR) redundancy—maximum number of flow-redirects.All platforms256 o
Policy-based routing (PBR) redundancy—maximum number of next hops per each flow-direct.All platforms32 o
Port-specific VLAN tags—maximum number of port-specific VLAN tags. 4120, 4220, 5120, 5320, 5420N/A
5520, 5720, 7520, 77201,023
Port-specific VLAN tags—maximum number of port-specific VLAN tag ports. 4120, 4220, 5120, 5320, 5420N/A
Private VLANs—maximum number of subscribers. Assumes a minimum of one port per network and subscriber VLAN.4120, 4220, 5120, 5320, 5420, 5520, 572036
7520, 772071
Private VLANs—maximum number of private VLANs with an IP address on the network VLAN.
Note: This limit is dependent on the maximum number of private VLANs in an L2-only environment if the configuration has tagged and translated ports.
4120, 4220, 5120, 5320, 5420, 5520, 5720960
7520, 77201,024
Private VLANs—maximum number of private VLANs in an L2-only environment.4120, 4220, 5120, 5320, 5420, 5520, 5720960
7520, 77201,280
Route policies—suggested maximum number of lines in a route policy file.All platforms10,000
RIP Learned Routes—maximum number of RIP routes supported without aggregation.5320-48T/P, 5320-24T-24S XT, 5420, 5520, 5720, 7520, 772010,000
5320-16P, 5320-24T/P 7,000
5320-24T-4X-XT900
4120, 512064
RIP interfaces on a single router—recommended maximum number of RIP routed interfaces on a switch.All platforms256
RIPng learned routes—maximum number of RIPng routes.5320-48T/P, 5320-24T-24S XT, 5420, 5520, 5720, 7520, 77203,000
512064
5320-16P, 5320-24T/P2,000
5320-16P-2MXT-2X496
5320-24T-4X-XT400
Spanning Tree (maximum STPDs)—maximum number of Spanning Tree Domains on port mode EMISTP. 5320-48T/P, 5420, 5520, 5720, 5320-24T-24S-4XE-XT, 7520, 772064
4120, 4220, 5120, 5320-24T/P, 5320-16P, 5320-24T-4X-XT 32
Spanning Tree PVST+—maximum number of port mode PVST domains.
Note: For all platforms, the maximum number of active ports per PVST domain depends on the maximum number of spanning tree ports supported on given platform. For example, for an ExtremeSwitching switch that supports 256 PVST domains (maximum) and 4,096 STP ports (maximum), the maximum number of active ports per PVST domain would be 16 ports (4,096 ÷ 256).
4120, 4220, 5120, 5320, 5320-24T-4X-XT, 5320-24T-24S-4XE-XT, 5420, 5520, 5720128
7520, 7720384
Spanning Tree—maximum number of multiple spanning tree instances (MSTI) domains. 5320-48T/P, 5320-24T-24S-4XE-XT, 5420, 5520, 5720, 7520, 772064
Spanning Tree—maximum number of VLANs per MSTI.
Note: Maximum number of 10 active ports per VLAN when all 500 VLANs are in one MSTI.
5320-48T/P, 5420, 5520, 5720, 7520, 7720600
4120, 4220, 5120, 5320-24T/P, 5320-16P; 5320-24T-4X-XT, 5320-24T-24S-4XE-XT256
Spanning Tree—maximum number of VLANs on all MSTP instances. 5320-48T/P, 5320-24T-24S-4XE-XT, 5420, 5520, 5720, 7520, 77201,024
4120, 4220, 5120, 5320-24T/P, 5320-16P, 5320-24T-4X-XT 512
Spanning Tree (802.1d domains)—maximum number of 802.1d domains per port.All platforms1
Spanning Tree (number of ports)—maximum number of ports including all Spanning Tree domains. 5320-48T/P, 5420, 5520, 5720, 7520, 77204,096
4120, 4220, 5120, 5320-24T/P, 5320-16P2,048
Spanning Tree (maximum VLANs)—maximum number of STP-protected VLANs (dot1d and dot1w). 5320-48T/P, 5320-24T-24S-4XE-XT, 5420, 5520, 5720, 7520, 77201,024
4120, 4220, 5120, 5320-24T/P, 5320-16P, 5320-24T-4X-XT600
SSH (number of sessions)—maximum number of simultaneous SSH sessions.All platforms8
Static MAC multicast FDB entries—maximum number of permanent multicast MAC entries configured into the FDB.All platforms1,024
Syslog servers—maximum number of simultaneous Syslog servers that are supported.All platforms16
Syslog targets—maximum number of configurable Syslog targets.All platforms16
Telnet (number of sessions)—maximum number of simultaneous Telnet sessions.All platforms8
Virtual routers—maximum number of user-created virtual routers that can be created on a switch. 5320-48T/P, 5420, 5520, 5720, 7520, 772063
4120, 4220, 5120, 5320-24T/P, 5320-16P16 (local-only VRs)
Virtual router forwarding (VRFs)—maximum number of VRFs that can be created on a switch.
Note: * Subject to other system limitations.
5320-48T/P, 5420, 5520, 5720, 7520, 7720960 *
Virtual router protocols per VR—maximum number of routing protocols per VR. 5320-48T/P, 5420, 5520, 5720, 7520, 77208
4120, 4220, 5120, 5320-24T/P, 5320-16PN/A
Virtual router protocols per switch—maximum number of VR protocols per switch. 5320-48T/P, 5420, 5520, 5720, 7520, 772064
VLAN aggregation—maximum number of port-VLAN combinations on any one superVLAN and all of its subVLANs.All platforms1,000
VLANs—includes all VLANs.
Note: Only 4,092 user-configurable VLANs are supported. (VLAN 1 is the default VLAN, and 4,095 is the management VLAN, and you may not configure them.)
All platforms4,094
VLANs (Layer 2)—maximum number of Layer 2 VLANs.All platforms4,094
VLANs (Layer 3)—maximum number of VLANs performing IPv4 and/or IPv6 routing. Excludes sub-VLANs.5320-48T/P, 54201,533
4120, 5120126
VLAN Port Interfaces (VPIF)—maximum number of VLAN port interfaces. 5120, 5320 40,000
542060,000
412032,000
422065,549
5520, 5720, 7520, 7720131,585
VLANs (maximum active port-based)—maximum active ports per VLAN when 4,094 VLANs are configured with the default license. 5520, 5720, 7520, 772032
4120, 4220, 512015
5320, 54203
VLANs (maximum active protocol-sensitive filters)—number of simultaneously active protocol filters in the switch.All platforms except 4120 and 4220.16
VLAN translation—maximum number of translation VLANs. Assumes a minimum of one port per translation and member VLAN.4120, 4220, 5120, 5320, 5420, 5520, 572036
7520, 772071
VLAN translation—maximum number of translation VLAN pairs with an IP address on the translation VLAN.
Note: This limit is dependent on the maximum number of translation VLAN pairs in an L2-only environment if the configuration includes tagged and translated ports.
7520, 77201,024
VLAN translation—maximum number of translation VLAN pairs in an L2-only environment.4120, 4220, 5120, 5320, 5420, 5520, 5720960
7520, 77202,046
VMAN CEP—maximum number of CVIDs.
Note: With 75% hash table utilization.
5520, 57209,000
VRRP (v2/v3-IPv4) (maximum instances)—maximum number of VRRP instances for a single switch. Normal Mode (as individual VRs):
Note: These limits are applicable for Fabric Routing configuration also.
All platforms except 4120, 4220, 5120511
4220508
4120, 512031
Note: Number of groups configured should not exceed the number of individual VRs supported (that is, in normal mode) for that platform type.
Scaled Mode (with groups):
Sliced Mode:
5120126
VRRP (v3-IPv6) (maximum instances)—maximum number of VRRP instances for a single switch. (VRRP-VRRPv3-IPv6)
4220508
4120, 512031
VRRP (v2/v3-IPv4/IPv6) (maximum VRID)—maximum number of unique VRID numbers per switch.All platforms except 4120, 5120255
4120, 512031
VRRP (v2/v3-IPv4/IPv6) (maximum VRIDs per VLAN)—maximum number of VRIDs per VLAN.All platforms except 4120 and 5120255
4120, 512031
VRRP (v2/v3-IPv4/IPv6) (maximum ping tracks)—maximum number of ping tracks per VLAN.All platforms8
VRRP (maximum ping tracks)—maximum number of ping tracks per VRRP Instance under 128 VRRP instances.All platforms8 (20 centisecond or 1 second hello interval)
VRRP (v3-IPv6) (maximum ping tracks)—maximum number of ping tracks per VRRP Instance under 128 VRRP instances.All platforms8 (20 centisecond or 1 second hello interval)
VRRP (v2/v3-IPv4/IPv6) (maximum iproute tracks)—maximum number of IP route tracks per VLAN.All platforms8
VRRP (v2/v3-IPv4/IPv6)—maximum number of VLAN tracks per VLAN.All platforms8
VXLAN—maximum virtual networks.
Note: Every VPLS instance/PSTag VLAN reduces this limit by 1.
Note: Assumption is all BUM (broadcast/unknown-unicast/multicast) FDB entries are pointing to the same set of RTEPs when all VNETs use explicit flooding. Depends on whether all VNETs use standard or explicit and the number of tenant VLAN ports.
Note: On ExtremeSwitching 5520 and 5420 switches, every VNET reduces this limit by 1.
Every (VPLS/PSTag VLAN) + port reduces the limit by 1 on all platforms.
Every VXLAN Underlay Multicast Tunnel reduces this limit by 1.
5520, 5720, 7520, 77202,048–4,000
5320, 5420150-375
VXLAN—maximum tenant VLANs plus port combinations
Note: Every (VPLS/PSTag VLAN) + port reduces the limit by 1.
5320, 5420150-375
VXLAN—maximum static MAC to IP bindings.
Note: Every FDB entry configured reduces this limit by 1.
All supported platforms except 4120 and 422064,000
VXLAN—maximum RTEP IP addressesAll supported platforms except 4120 and 4220512
VXLAN—maximum virtual networks with dynamic learning and OSPF extensions for VXLAN 5520, 5720, 7520, 77204,000
5320, 5420375
VXLAN—or replicator role, maximum number of attached leafs per switch.All supported platforms except 4120 and 4220256
XML requests—maximum number of XML requests per second.
Note: Limits are dependent on load and type of XML request. These values are dynamic ACL data requests.
All platforms10 with 100 DACLs
XNV authentication—maximum number of VMs that can be processed (combination of local and network VMs).All platforms except 4120 and 42202,048
XNV database entries—maximum number of VM database entries (combination of local and network VMs).All platforms except 4120 and 422016,000
XNV database entries—maximum number of VPP database entries (combination of local and network VPPs).All platforms except 4120 and 42202,048
XNV dynamic VLAN—Maximum number of dynamic VLANs created (from VPPs /local VMs).All platforms except 4120 and 42202,048
XNV local VPPs—maximum number of XNV local VPPs.All platforms except 4120 and 4220
2,048 ingress
512 egress
XNV policies/dynamic ACLs—maximum number of policies/dynamic ACLs that can be configured per VPP.All platforms except 4120 and 4220
8 ingress
4 egress
XNV network VPPs—maximum number of XNV network VPPs.pAll platforms except 4120 and 4220
2,048 ingress
512 egress
