The following table shows the default settings for Switch Engine starting with version 31.6, and shows any changes that have been made to these settings and in what version these changes were made.
| Feature | 31.6 and later | 32.4 and later |
| 1G behavior in 10G ports (5420 and 5520 series switches) | Autoneg OFF for port when 1G optic is inserted in a 10G port | |
| Account Lockout | After 3 consecutive login failures, account is locked for 5 minutes. a | |
| Auto-Discovery for Universal Hardware | Enabled. | |
| AVB | Disabled. | |
| BFD Strict Session Protection | Disabled. | |
| BGP | Disabled. | |
| Bluetooth | Enabled. | |
| BOOTP Relay | Disabled. | |
| CDP | Enabled. | |
| Configuration auto save | Disabled. | |
| Clear-flow | Disabled. | |
| Diagnostics | Admin level privileges required to show diagnostics. a | |
| DHCP | Disabled. | |
| DNS Cache Resolver and Analytics | Disabled. | |
| IPFIX | Disabled. | |
| IP NAT | Disabled. | |
| EAPS | Disabled. | |
| EDP | Enabled. | |
| ELRP | Disabled. | |
| ESRP | Disabled. | |
| Extended Edge Switching (VPEX) | Disabled. | |
| ExtremeCloud IQ | Enabled | |
| FEC | Enabled on Native 25Gb ports. | |
| Identity Management | Disabled. | |
| IGMP | Enabled, set to IGMPv2 compatibility mode. | |
| IGMP Snooping | Enabled. | |
| Image Integrity Check | Disabled. | |
| IP Route Compression | Enabled. | |
| ISIS | Disabled. | |
| LLDP | Enabled. | |
| Log | Admin level privileges required to show log. a | |
| Logging memory buffer | Generate an event when the logging memory buffer exceeds 90% of capacity. a | |
| MAC Security | Disabled. | |
| MLD | Disabled. | |
| MLD Snooping | Disabled. | |
| MPLS | Disabled. | |
| MSRP | Disabled. | |
| MSTP | Enabled. | |
| NetLogin | All types of authentication are disabled. | |
| NTP | Disabled. | |
| ONEPolicy | Disabled. | |
| Policy rule model | Hierarchical (Unless upgrading from 30.5 with a saved configuration set to access list.) | |
| OpenFlow | Disabled. | |
| OSPF | Disabled. | |
| OVSDB | Disabled. | |
| Passwords | Plain text password entry not allowed. a | |
| PIM | Disabled. | |
| PIM Snooping | Disabled. | |
PoE Fast PoE Perpetual PoE |
Enabled. Disabled. Disabled. | |
| RADIUS | Disabled for both switch management and network login. | |
| RIP | Disabled. | |
| RMON | Disabled. However, even in the disabled state, the switch responds to RMON queries and sets for alarms and events. | |
| sFlow | Disabled. | |
| SNMP server | Disabled. a | |
| SSH | Disabled. | |
| Stacking-support | Enabled. | Disabled for 5120, Extreme 7520, and 7720 only. |
| Stacking auto-discovery | Enabled. | |
| STP | Enabled. | |
| Syslog | Disabled. | |
| TACACS | Disabled. | |
| Telnet | Enabled. a | |
| VPEX IP Multicast Replication | BPE | |
| VPLS | All newly created VPLS instances are enabled. | |
| Watchdog | Enabled. | |
| Web HTTP server | Enabled. a | |
| Web HTTPS server | Enabled. a |
