OpenAPI Server Management
Version 33.6 adds user-accessible commands to manage the OpenAPI server, enabling integration with third-party management tools such as Ansible while maintaining compatibility with IQAgent cloud management.
Enhancement: The OpenAPI server, previously managed exclusively by IQAgent for internal cloud applications, is now available for customer use using HTTP (port 80) or HTTPS (ports 443/9443). You can enable, disable, and restart the OpenAPI server through CLI commands. When IQAgent is enabled, it automatically keeps the OpenAPI server operational regardless of user configuration, ensuring uninterrupted cloud connectivity.
Key Capabilities:
IQAgent Behavior
When IQAgent is enabled, the OpenAPI server remains operational regardless of user configuration. Attempting to disable the server displays the following message:
Note: The OpenAPI server is required by IQAgent and will remain operational
while IQAgent is enabled.
This ensures continuous cloud connectivity while allowing users to manage the server when IQAgent is not in use.
Server Status Values
New CLI Commands
Enable, disable, or restart the OpenAPI server:
enable openapi
disable openapi
restart process openapi
Display OpenAPI server status:
show openapi
Supported Platforms
All platforms.
