To upload an engine application Docker image, take the following steps:
Go to .
Choose one of the following:
- Select the Choose Image File pane and navigate to
the image file. Or,
- Drag and drop the image file onto the Image File
pane.
A list of uploaded image files is displayed below the
Choose
Image File pane.
- To delete an uploaded image, select the check box next to the image
file. Then, select
- To refresh the image file list, select
After you have uploaded the necessary engine application image file, go to
and select the engine instance that you want to upgrade.
