Use the Application screen to create custom application definitions.
The WiNG 7.1.X release does not support third-party DPI engine on the AP5XX model access points. WiNG 7.1.2 supports EAA (Extreme Application Analytics) (Purview™) DPI engine on the WiNG 7.1.X APs. For more information , refer the WiNG 7.1.2 CLI Reference guide, available at https://extremenetworks.com/documentation.To create a user-defined application:
| Name | Displays the name of each user-defined application created using this application interface. |
| Category | Lists the category to which each listed user-defined application belongs. |
| Application Description | Lists the 80 character maximum description administratively assigned to each listed user-defined application. |
| Network Service | Use the drop-down menu to select an existing network service alias for the user-defined application. If there are no existing network service alias suited to this new user-defined application, select the Create icon to define a new alias or the Edit icon to modify an existing one. Provide or modify a 32 character maximum name, along with a protocol type or number and source and destination port value. Up to four (4) service aliases can be supported. |
| URL List | defined application. URL lists are utilized for whitelisting and blacklisting Web application URLs from being launched and consuming bandwidth within the WiNG managed network. If no URL list suits this new user-defined application, select the Create icon to define a new list or the Edit icon to modify an existing URL list. |
| HTTPS | Select the + Add Row button to populate the table with configurable rows for HTTPS parameter type, attribute type, match criteria for the HTTPS server name and 64 character maximum server name attribute used in the HTTPS server message exchange. |
Select Reset to revert to the last saved configuration.
