NX-7500 Series Integrated Services Platform Power Supply
Installation
![Warning](../../images/Warning_Note.png)
Warning
Power down the the integrated services platform and disconnect all
power cords prior to installing or replacing a power supply.
![Caution](../../images/Caution_Note.png)
Caution
Ensure that the connectors at on the back of the power supply do
not come into contact with your hands or the packing material as you unpack the
power supply. Avoid damaging the connectors as you insert the power supply into the
integrated services platform.
To remove a power supply and install a replacement power supply:
Remove the power cord from the power supply to be
replaced.
Push the locking latch to the right and remove the power supply.
Unpack the AC or DC power supply module and carefully insert it into the
NX-7500 integrated services platform.
Press the locking latch to lock the power supply in place.
Observe that the power supply light is illuminated to verify that the power
supply is operating properly.
