Extreme Networks
Extreme Fabric Automation Administration Guide Version 2.7.1. > Extreme Fabric Automation > REST API Documentation for EFA >
Published June 2022
Search this documentPrint this pageEmail this pageView PDFPreviousNext
  • Preface
    • Text Conventions
    • Documentation and Training
    • Help and Support
    • Send Feedback
  • About this Document
    • What's New in this Document
  • Extreme Fabric Automation
    • Introduction to Extreme Fabric Automation
    • EFA Microservices
    • REST API Documentation for EFA
      • Access Northbound API
  • EFA System Management
    • Verify the Running System and Services
    • Log in to EFA
    • EFA Certificate Management
      • Northbound Interface Certificates
      • Device Certificates
        • HTTPS Certificates
        • Syslog CA
      • Certificate Expiry and Renewal
      • Certificate Troubleshooting
    • Monitoring EFA Status
    • Verifying EFA System Health
    • EFA System Backup and Restoration
      • Back up and Restore the EFA System
    • Change the Host Name or IP Address
    • Display EFA Running Configurations
    • Audit Trail Logging
      • Transfer of Audit Trail Data
    • Logging and Log Files
    • Data Consistency
      • Periodic Device Discovery
      • Persistent Configuration
      • Drift and Reconcile
      • Network Elements
      • Idempotent Operations
      • Rollback Scenarios for Data Consistency
    • EFA High Availability Failover Scenarios
    • Multiple Management IP Networks
      • Add and Delete Management Routes
        • Configuration Supporting Multiple Management IP Networks
      • Add and Delete Management Subinterfaces
      • Configure Static IP Addresses for Management Subinterfaces
      • Change the Default Gateway of a TPVM
  • Fabric Infrastructure Provisioning
    • Fabric Service Overview
    • IP Fabric and Clos Orchestration Overview
    • SLX Device Prerequisites for Fabric Service
    • Clos Overview
    • Configure a 3-Stage Clos Fabric
    • Configure a 5-Stage Clos Fabric
    • Overview of Day-0 Operations for a Small Data Center Fabric
    • Supported Small Data Center Topologies
    • Configure a Small Data Center Fabric
      • Dynamic ICL in small data center
    • IP Multicast Fabric Provisioning
      • IP Multicast Fabric Overview
      • Bidirectional Forwarding Detection
      • Fabric Settings to Update BGP MD5 Password, BGP Dynamic Peer Listen Limit, and Single Rack Deployment
      • Configure an IP Multicast Fabric
      • Device Configuration
      • Configure Drift and Reconcile on Multicast Fabric
    • View Fabric Details
    • Edit Fabric Settings
    • Fabric Event Handling
    • Northbound IPv6 support
  • Tenant Services Provisioning
    • Tenant Services Provisioning Overview
    • Provisioning a Tenant
    • Clos Fabric with Non-auto VNI Maps
    • Clos Fabric with Auto VNI Map
    • Layer 3 Network Services
      • Configure Description on Port Channel
      • Configure Minimum Link Count on Port Channel
      • Configure Backup Routing on Tenant VRF
      • Route-Distinguisher (RD) allocation independent of Route-Target (RT)
      • Configure Static VRF Route
      • Configure BFD on Static VRF Route
      • Configure Local ASN on Tenant VRF
        • Update Local ASN on VRF
          • Backup Routing
          • Configure Local ASN during VRF Create
          • Configure Local ASN During VRF Update
          • Deconfigure Local ASN during VRF Update
      • Enable Graceful Restart on Tenant VRF
      • Configure Resilient Hashing on Tenant VRF
      • Configure MaxPaths on Tenant VRF
      • Configure Redistribute Attribute on Tenant VRF
      • Configure Advertise Network and Static-Network on Tenant VRF
      • Configure Aggregate Address on Tenant VRF
      • EPG: Network Property Description
      • Update anycast-ip on an Existing Tenant Network
      • Configure Multiple Anycast IP
      • Configure IPv6 ND on a Tenant Network
      • Configure the BFD Session Type for an Endpoint Group
      • Configure CEP Cluster Tracking for Endpoint Groups
        • Enable Cluster Tracking on CEP Interfaces
      • Suppress Address Resolution Protocol and Neighbor Discovery on VLAN or Bridge Domain
      • Configure Local IP for Endpoint Group
      • EPG: Network Property: IP MTU
      • BGP as a Service
        • BGP Peer Group
        • BGP Static Peer
        • BGP Dynamic Peer
          • Configure Listen Limit on BGP Dynamic Peer
        • Getting the operational state of the BGP peers
        • Configure route map attribute
        • Configure remove-private-as on BGP Peer
        • Configure remove-private-as on BGP Peer Group
        • Configure default-originate to advertise default route on BGP Peer
        • Configure Backup Routing Neighbors on BGP Peer
      • IPv6 Support
      • Software BFD Session Support on CEP
      • Exclusion of VLANs and Bridge from Cluster Instance
      • Sharing Resources Across Tenants using Shared Tenant
        • Shared VRF and Router
          • Configure Shared Tenant, Shared VRF, and Private EPG using Shared VRF
          • Configure L3-Hand-Off EPG and BGP Peer under Ownership of Shared Tenant
          • Shared VRF and Router Usecase with Examples
          • Sharing Multiple VRFs with the same RT (route-target)
      • Distributed and Centralized Routing
        • Prepare Clos Fabric for Centralized Routing
        • Prepare Small Data Center Fabric for Centralized Routing
        • Enable Centralized Routing on Tenant VRF
        • Configure physical routers for centralized routing on Tenant VRF
        • Configure anycast-ip on Tenant Endpoint Group
        • Configure local-ip on Tenant Endpoint Group
        • Configure static route on tenant VRF
        • Configure static route BFD on Tenant VRF
        • Configure peer-group on Tenant BGP
        • Configure static peer on Tenant BGP
        • Configure Dynamic peer on Tenant BGP
        • Centralized Routing on Single Rack Small Data Center Leaf Pair (not Border Leaf Pair)
          • Create a Tenant VRF for Single Rack Small Data Center Leaf Pair Deployment
          • Configure a Single-Rack Leaf in Day 0 and Day 1 Provisioning
      • BFD timers for router-bgp BFD and static-route BFD sessions
    • Administered Partial Success
      • Administratively Manage a Device State
      • APS Behavior of Tenant Configuration
        • Existing behavior in EFA 2.3.0
        • APS: Pre-provisioning Support by Modifying the Target Device List to Include the MCT Neighbor
        • APS: Deletion Support for Pre-provisioned Configurations
    • In-flight Transaction Recovery
    • Traffic Mirroring
      • In-band Traffic Mirroring
      • Out-of-band Traffic Mirroring
      • Support Matrix
      • Configure Port-Based Mirroring in a Multi-Tenant Architecture
      • Configure Flow-Based Mirroring in a Multi-Tenant Architecture
        • Access Control List and Data Consistency Support
      • Configure VLAN-Based Mirroring in a Multi-Tenant Architecture
      • Configure ICL Port Mirroring in a Multi-Tenant Architecture
    • Scalability
  • Policy Services Provisioning
    • Policy Services Provisioning Overview
    • Prefix List
    • Configure IP Prefix List on Devices
      • Drift and Reconcile (DRC) and Idempotency for IP prefix list configuration
    • Route Map
    • Configure Route Map on devices
      • Drift and Reconcile (DRC) and Idempotency for route map configuration
    • Event handling for IP prefix list and route map
  • EFA Device Management
    • Device Image Management
      • Hitless Firmware Upgrade
        • Upgrading the Super-Spine Firmware in Clos
        • Upgrading the Spine Firmware in Clos
        • Upgrading the Firmware of an MCT Leaf Pair with Dual-Homed Servers in Clos
        • Upgrading the Firmware of a Three-Rack Centralized MCT Pair in Small Data Center
        • Upgrading the Firmware of a Three-Rack Ring MCT Pair in Small Data Center
      • Firmware Download
        • Firmware Upgrade with Minimal Traffic Loss
        • Firmware Download Restart on HA Failover or Inventory Service Restart
        • Firmware Download Implicit Fullinstall Support
        • EFA Command Blocking During Firmware Download
        • Failures During Group-based Firmware Download Execution
        • Group-based Firmware Download Restore
      • Fabric-wide Firmware Download
        • Group-based Firmware Download Preparation
        • Fabric-based Firmware Download Preparation
        • Group-based Firmware Download Execution
      • Roll Back Device Firmware
      • Traffic Loss Scenarios
    • Device Health Management
      • Monitor Device Health
    • Device Configuration Backup and Replay
      • Configure Backup and Replay
    • Return Material Authorization
      • Replace a Faulty Device
    • SLX Device Configuration
      • Compare a Device
      • Enable Maintenance Mode on SLX Devices
      • Configure Physical Port Speed
      • Configure Breakout Ports
      • Configure MTU at the Interface or System Level
      • Change the Admin Status of an Interface
      • Configure NTP at Device and Fabric Levels
      • Configure RME on Interface
      • Device Configuration Synchronization
      • SLX Configuration Backup
        • CLI Commands for Backups
  • EFA Event Management
    • RASlog Service
      • RASlog Operations
    • Notification Service
    • EFA as SNMP Proxy
      • Drift and Reconcile (DRC) and Idempotency for SNMP
  • Known Limitations
    • Known Limitations in EFA
9037424-01 Rev AA
  • © 2024 Extreme Networks.
  • Legal
  • Privacy and Cookies Policy
