# efa inventory device setting update --ip 10.24.14.133 --config-backup-periodic-enable yes
efa inventory device setting update --ip 10.24.14.133 --config-backup-interval 30m [3m-1800m, default 1440m] # efa inventory device setting update --ip 10.24.14.133 -–number-of-config-backups 2 [2-20, default 4] # efa inventory config-backup execute --ip 10.24.14.133
# efa inventory config-backup history --ip 10.24.14.133 # efa inventory config-backup detail –-uuid 1111-1111-1111 --show-config # efa inventory config-backup detail –-uuid 1111-1111-1111 --show-config -–file-dump <filename>
# efa inventory config-backup delete --key 10.24.14.133 # efa inventory config-backup delete --key 1111-1111-111
The startup-config backup restore method requires device reboot to restore the configuration.# efa inventory config-replay execute --ip 10.24.14.133 --uuid 1111-1111-111 --startup-config --no-reboot
# efa inventory config-replay execute --ip 10.24.14.133 –-uuid 1111-1111-111
# efa inventory config-replay history --ip 10.24.14.133 # efa inventory config-replay detail –-uuid 1111-1111-1111
# efa inventory config-replay delete --key 10.24.14.133 # efa inventory config-replay delete --key 1111-1111-111
