Event handling reason code is generated only in case of a drift in configuration at the device after EFA fabric is configured. The following listed events generated by RASlog event or device update is handled in fabric services:
The efa fabric show command displays all the events handled at fabric services.
CONFIG GEN REASON: LA/LD - Link Add/Delete, IA/ID/IU - Interface Add/Delete/Update, PLC/PLD/PLU - IPPrefixList Create/Delete/Update MD/MU - MCT Delete/Update, OD/OU - Overlay Gateway Delete/Update, EU/ED - Evpn Delete/Update, PC/PD/PU - RouterPim Create/Delete/Update DD - Dependent Device Update, DA/DR - Device Add/ReAdd, ASN - Asn Update, SYS - System Properties Update MD5 - BGP MD5 Password, BGPU - Router BGP Update, BGPLL - BGP Listen Limit, POU - Port Channel Update, NA - Not Applicable
| Drift (SLX vs EFA) | App State | CONFIG GEN REASON (efa fabric show) |
| Evpn | Cfg-refresh | EU/ED - Evpn Delete or Update |
| Cluster | Cfg-refresh | MD/MU - MCT Delete or Update |
| Router bgp | Cfg-refresh | BGPU - Router BGP Update |
| Overlay gateway | Cfg-refresh | OD/OU - Overlay Gateway Delete/Update, |
| Interface ( Phy/ Lo/Po) | Cfg-refresh | IA/ID/IU - Interface Add, Delete or Update |
| LLDP | Cfg-refresh | LA/LD - Link Add or Delete |
