The Advanced Edge License includes all Edge License features and the features in the following table.
ExtremeXOS Advanced Edge License Features
ExtremeXOS Software Feature | Supported Platforms |
EAPS Advanced Edge (multiple physical rings) | All platforms. |
ERPS-more domains (allows 32 rings with matching ring ports) and multi-ring support | All platforms. |
ESRP-Full | All platforms. |
ESRP-Virtual MAC | All platforms. |
OSPFv2-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
OSPFv3-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
PIM-SM-Edge (limited to max of 4 active interfaces) | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
VRRP | All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches). |
VXLAN | Summit X770, X670-G2, and ExtremeSwitching X870. |
OVSDB | Summit X770, X670-G2, and ExtremeSwitching X870. |
PSTag | All platforms. |
