Following discovery, an FA Proxy or FA Client transmits locally-defined I-SID/VLAN assignments through FA Signaling to an FA Server, which accepts or rejects these assignments.
The I-SID/VLAN assignment acceptance by the server can require actions to be performed by the FA agent on both the FA Proxy and the FA Server, to appropriately configure the communication channel (uplink) between the FA Proxy or FA Client and FA Server. Most actions undertaken based on assignment acceptance are undone when the I-SID/VLAN assignment is no longer needed.
I-SID/VLAN assignment rejection by the FA Server requires the FA Proxy/Client to clean up any settings that the FA agent made related to feature operation, as well as log the rejection and any associated error type information for later analysis by an administrator.
No more than a single log message is generated for a rejected I-SID/VLAN assignment, regardless of how many times the assignments have been requested and rejected. Assignments that are rejected, accepted, and later rejected result in a log message being generated for each “new” rejection (two I-SID/VLAN assignment rejection log messages are generated in this case).
Create port-based VLAN corresponding to I-SID/VLAN assignment VLAN.
Update port VLAN membership to include I-SID/VLAN assignment VLAN.
Create SPBM switched UNI VLAN corresponding to I-SID/VLAN assignment VLAN.
C-VLAN join operation does not initiate VLAN creation (VLAN already exists and is associated with the I-SID/VLAN binding I-SID).
Update I-SID/VLAN mapping data to ensure Shortest Path Bridging-MAC (SPBM)-switched UNI support is enabled for the I-SID/VLAN/port tuple (in other words, create switched UNI). Port VLAN membership is updated by this action.
Additional actions can be required for I-SID/VLAN binding state transitions involving FA Client-generated data. The communication channel (that is, the downlink) between the FA Client and FA Proxy must be appropriately configured. This can require actions to be performed on the switch.
Update downlink port VLAN membership to include I-SID/VLAN assignment VLAN.
Each of these actions is performed by the FA Proxy and FA Server for each I-SID/VLAN assignment, unless the required data/settings have already been configured by the administrator. The successful transition from ‘pending‘ to ‘active‘ is gated by the successful completion of these actions. The FA agent tracks which settings have been updated based on I-SID/VLAN assignment processing (comparing them with settings established by the administrator), and cleans-up or undoes the settings that are related to I-SID/VLAN assignment support as much as possible when an assignment is no longer needed.
I-SID/VLAN assignment state transitions from ‘active‘ to ‘rejected‘ require complementary actions be performed by the FA Proxy/Client and the FA Server to eliminate assignment-related settings:
Update uplink port VLAN membership to exclude I-SID/VLAN assignment VLAN.
Delete port-based VLAN corresponding to I-SID/VLAN assignment VLAN.
Delete I-SID/VLAN/port association data to disable SPBM-switched UNI support for the I- SID/VLAN/port tuple (to delete switched UNI). This action updates port VLAN membership.
Delete SPBM-switched UNI VLAN corresponding to I-SID/VLAN assignment VLAN.
Previously joined C-VLANs are not deleted.
State transitions related to FA Client-generated bindings require additional complementary actions to be performed by the FA Proxy to eliminate assignment-related settings:
FA Proxy external client proxy I-SID/VLAN assignment deletion actions:
Update downlink port VLAN membership to exclude I-SID/VLAN assignment VLAN.
Assignment status data returned by the FA Server for each pending I-SID/VLAN assignment drives the FA Proxy response processing. Assignment rejections can include information to indicate the reason for the rejection.
FA resources unavailable(4)–the resources that are required for the FA agent to support additional I-SID/VLAN assignments are currently exhausted. The maximum number of assignments that can be supported has been reached.
VLAN invalid(6)–the specified VLAN can‘t be used to create a switched UNI at this time. The VLAN already exists and is either inactive or has an incorrect type for this application. This error is also returned if an FA Client or FA Proxy exports an bindings with an I-SID value of 0 and SPBM provisioning is enabled.
VLAN resources unavailable(8)–the maximum number of VLANs that can be supported by the device has been reached.
Application interaction issue(9)–a failure has been detected during FA interactions with the VLAN and/or the SPBM applications. The VLAN operations to create the required SPBM switched UNI VLAN or enable port tagging may have failed or the SPBM operation to create the switched UNI may have failed.
As with the actions initiated to support an assignment addition, actions related to assignment deletion are performed only if the targeted data was created during the I-SID/VLAN assignment addition phase. Previously-existing configuration data is not changed. No artifacts are left behind to indicate that automated operations have taken place, following an addition or deletion sequence. This goal may not always be achievable but all attempts are made to satisfy this requirement.
I-SID/VLAN assignment timeout–A “last updated” timestamp is associated with all active assignments on the FA Server. When this value is not updated for a predetermined amount of time, the I-SID/VLAN assignment is considered obsolete. Obsolete assignment data and related settings are removed by the FA server agent. The timeout duration value allows FA Server settings to be maintained if temporary connectivity issues are encountered.
I-SID/VLAN binding timeout is also performed by an FA Proxy when it is providing client proxy services and FA Client data is present. Processing similar to that performed by the FA Server related to data aging is supported.
I-SID/VLAN assignment list updates–The current I-SID/VLAN assignment list is advertised by an FA Proxy at regular intervals (dictated by FA Signaling). During processing of this data, an FA Server must handle list updates and delete assignments from previous advertisements that are no longer present. Though these entries would be processed appropriately when they timeout, the FA agent attempts to update the data in real-time and initiates deletion immediately upon detection of this condition.
FA Server inactivity timeout–If primary FA Server advertisements are not received for a predetermined amount of time, the I-SID/VLAN assignments accepted by the server are considered rejected. I-SID/VLAN assignment data is defaulted (reverts to the ‘pending‘ state) and related settings are removed by the FA Proxy agent. The timeout duration value has been chosen to allow FA Proxy settings to be maintained if temporary connectivity issues are encountered.
You can configure the timeout value used for FA device or binding aging with the fa timeout command. The default value is 240 seconds.
