show fa
Displays Fabric Attach specific settings.
Syntax
Command Parameters
<LINE>
List of ports
agent
Displays the Fabric Attach agent status.
assignment <1-16777214>
Displays Fabric Attach configured UNIs.
auth-status {auth-fail | auth-pass | not-auth}
Displays only specified authorized status.
client-type
Displays only the specified client type.
disabled-auth
Displays only disabled authorized ports.
disabled-port
Displays only disabled ports.
elements
Displays discovered Fabric Attach elements.
element-type
Displays only the specified element type.
enabled-auth
Displays only enabled authorized ports.
enabled-port
Displays only enabled ports.
interface
Displays Fabric Attach port settings.
i-sid <1-16777214>
Displays the Fabric Attach configured user-to-network interface (UNIs).
port-enable <LINE>
Displays the Fabric Attach port settings.
statistics
Displays the FA summary and per-port statistics counters.
summary
Displays Fabric Attach summary statistics.
Default
None
Command Mode
User Executive
