Software licensing configuration tasks
This section describes the configuration tasks for generating and obtaining a software license, and then installing it on the device. Perform the tasks in the order as given in the following list.
Following are the configuration tasks for software licensing:
  1. Order the desired license.
  2. After ordering the license, you will receive a fulfillment email containing the Voucher ID.
  3. Retrieve the LID of the device by entering the show license id command on the device. You must use the Line Card LID to obtain licenses for the Line Cards.
  4. Log in to the Extreme Portal located here: https://extremeportal.force.com/ExtrLicenseLanding. If you do not have an account yet, log in to https://secure.extremenetworks.com.
  5. Upload the license file to the device.
  6. Verify that the license is installed.
Do not discard the fulfillment email with the VID in case it is needed for technical support or product replacement (RMAs).
