Before you can use a software license, you must generate it from the
Extreme portal.
The following procedure demonstrates how to generate and obtain a software license.
Log in to the
Extreme Portal at
https://extremeportal.force.com/ExtrLicenseLanding.
If you do not have an Extreme
portal account, select Create
a new Extreme Portal account.
The following figure shows the
Extreme Portal login window.
Extreme portal login
window
Enter your email and password.
Click Log
In.
The
Licenses Home
window appears.
Licenses Home
window
Select
Assets
Licenses Home option. Click
Generate License.
The
Generate License window is displayed.
Enter the VID. Click
Next.
The VID (previously known as Transaction Keys at Brocade) has 20 alphanumeric characters with hyphens.
Unredeemed Transaction Keys from Brocade can still be redeemed.
Enter the unique identifier of the HW (or the serial number of the LID). Click
Submit.
You must check the box to agree to the Terms and Conditions.
HW serial number window
The VID is displayed. The example below displays voucher information for a non-capacity license.
Click
Download to download a copy of the license.
A license can be downloaded after license generation or when a unit is queried. The license is not emailed.
In example below, the contents of the XML license are displayed, including the license SKU and license keys.
License file window
