Enabling MVRP on an Ethernet interface
Perform the following steps to enable MVRP on an Ethernet interface.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Add a VLAN on a device that will be added to the interface.
    device(config)# vlan 10
    This command accesses VLAN configuration mode.
    device(config-vlan-10)#
  3. Access global configuration mode.
    device(config-vlan-10)# exit
  4. Enable MVRP globally on the device.
    device(config)# protocol mvrp
    This command accesses MVRP configuration mode.
    device(config-mvrp)#
  5. Access global configuration mode.
    device(config-mvrp)# exit
  6. Configure an Ethernet interface and access interface configuration mode.
    device(config)# interface ethernet 0/1
  7. Place the interface in Layer 2 mode.
    device(conf-if-eth-0/1)# switchport
  8. Set the Layer 2 interface as trunk.
    device(conf-if-eth-0/1)# switchport mode trunk
    Trunk mode makes the port linkable to other switches and routers.
  9. Add the VLAN to the interface as tagged.
    device(conf-if-eth-0/1)# switchport trunk allowed vlan add 10
  10. Enable MVRP on the interface.
    device(conf-if-eth-0/1)# mvrp enable
  11. Enable the interface.
    device(conf-if-eth-0/1)# no shutdown
  12. Display the MVRP status of the configuration.
    device(conf-if-eth-0/1)# do show mvrp
    Total configured mvrp ports     :       1
    Global Status                   :       Enabled
    Join-timer(in centiseconds)     :       20
    Leave-timer(in centiseconds)    :       100
    Leaveall-timer(in centiseconds) :       1000
    MVRP Port(s): ethe 0/1
The following example provides the steps in the previous configuration.
