Describes the process to configure routing VE over VPLS.
Virtual Private LAN Services (VPLS) enables you to connect remote sites over Multiprotocol Label Switching (MPLS) domain as if these sites were connected by a Layer 2 switch. It enables Virtual Circuits (VCs) to provide point-to-multipoint connection across the MPLS domain allowing traffic to flow between these remote sites on your Virtual Private Network (VPN).
Provider Edge equipments try to learn the MAC address of locally connected devices by flooding the broadcast and unknown unicast frames to other Provider Edge devices within the VPN. Associations are made between the remote MAC addresses and the VC Lable Switched Paths (LSPs) used to reach these remote PE devices. Traffic is then routed over these learned LSPs for any frame for the destination PE devices.
For SLX 9640 and SLX 9740, enabling routing over BD for VE over VPLS is not supported when the pseudo wire profile on the bridge domain is in Tag mode. Due to this, the following will not be allowed on the CLI:
Enabling routing on bridge domain which has pseudo wire profile mode set as Tag.
Changing pseudo wire profile to Tag mode in case the pseudo wire profile is associated with any bridge domain that has routing enabled on it.
VE over VPLS will route packets between VPLS VE interface and all other IP interfaces outside of VPLS domain which reside on the PE devices. These include:
Physical Interfaces.
Other VLAN based VE interfaces for both tagged and un-tagged ports.
VE interfaces which reside on other VPLS instances.
The following is an example of a complete configuration for VE over VPLS:
ip proxy-arp
ip address 15.15.15.15/24
no shutdown
interface Ethernet 1/1
switchport
switchport mode trunk
switchport trunk allowed vlan add 100
switchport trunk tag native-vlan
no shutdown
logical-interface ethernet 1/1.15
vlan 15
bridge-domain 15 p2mp
vc-id 15
router-interface ve 15
pw-profile vplsPWprofile
bpdu-drop-enable
local-switching
vc-mode tag
