Bypass LSPs can be made adaptive by using the
		adaptive command. By default, bypass LSPs are non-adaptive . The user can modify the adaptive bypass LSP adaptive-parameters without disabling the LSP. When the LSP is UP, then modifying an adaptive parameter, such as exclude-interface or bandwidth, leads to the creation of a new instance of the bypass LSP. Adaptiveness can be manually enabled by using the
		adaptive command and can be disabled by
		no adaptive for of the same command.
		To make the bypass LSP adaptive, complete the following steps.
		  Enable the device for configuration.
		  Enable the MPLS router.
			 device(config)# router mpls
		   Configure the bypass LSP with the unique static bypass LSP name of
			 my-bypass-lsp
			 device(config-router-mpls)# bypass-lsp my-bypass-lsp
		  Configure the command to be adaptive.
			 device(config-router-mpls-bypass-lsp-my-bypass-lsp)# adaptive
		The following example combines the steps above to configure a static bypass LSP as adaptive with a unique bypass LSP name of
		  my-bypass-lsp
		device>configure
