Configures, modifies, or retrieves ACL configuration.
| URI | Description |
| <base_URI>/config/running/acl-policy | Configures ACL policy. |
| GET URIs | Description |
| <base_URI>/config/running/acl-policy/allow-conflicting-rules | Allows conflicting rules in a ACL table. |
| <base_URI>/config/running/acl-policy/allow-duplicate-rules | Allows duplicate rules in a ACL table. |
| POST URIs | Payload | Description |
| <base_URI>/config/running | <acl-policy>()</acl-policy> | |
| <base_URI>/config/running/acl-policy/allow-conflicting-rules | <allow-conflicting-rules>true</allow-conflicting-rules> | Allows conflicting rules in a ACL table. |
| <base_URI>/config/running/acl-policy/allow-duplicate-rules | <allow-duplicate-rules>true<allow-duplicate-rules> | Allows duplicate rules in a ACL table. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/acl-policy/allow-conflicting-rules | <allow-conflicting-rules /> | Allows conflicting rules in a ACL table. |
| <base_URI>/config/running/acl-policy/allow-duplicate-rules | <allow-duplicate-rules /> | Allows duplicate rules in a ACL table. |
| PUT URIs | Payload | Description |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to display whether duplicate rules are allowed.
http://host:80/rest/config/running/acl-policy/allow-conflicting-rules
None
<allow-conflicting-rules xmlns="urn:brocade.com:mgmt:brocade-acl-policy" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/acl-policy/allow-conflicting-rules">true </allow-conflicting-rules>
The following is an example PATCH operation to allow duplicate rules in a ACL table.
None
The following is an example of the DELETE operation to remove the ACL policy.
None
None
