Updates the HTTP application URL.
| URI | Description |
| <base_URI>/operations/set-http-application-url | Update HTTP application URL. |
Only POST operation is supported.
http://host:80/rest/operations/set-http-application-url
<set-http-application-url>
<config-http-app-url>
<url>www.google.com</url>
<op-type>0</op-type>
</config-http-app-url>
</set-http-application-url>
<output xmlns='urn:brocade.com:mgmt:brocade-http-redirect'> <status-code>0</status-code> <status-string>Success</status-string> </output>
