Logical interfaces overview
A logical interface (LIF) serves the purpose of abstracting a forwarding interface in a very generic way, making it possible to capture the underlying physical characteristics of a forwarding interface.
This feature facilitates the support of future forwarding technologies without the need to modify code design in various software components.
A forwarding interface is also known as "main interface." It can be a physical port, a port-channel (Link Aggregation Group, or LAG), a pseudowire (PW), a tunnel, and so on. A logical interface can also be thought of as a subinterface configuration on top of a main interface.
Currently the only LIFs that require explicit user configuration are attachment circuit (AC) LIFs.
Draft comment:
For the maximum number of LIFs supported for physical ports and LAG interfaces, PWs, and the overall system, refer to the Release Notes. [>>>add to RN]
The maximum number of attachment circuit (AC) LIFs allowed per interface type is shown in the following table.
Table 1. LIF scalability
Type Maximum number of LIFs
Physical port/LAG interface 12 K
Pseudowire 8 K
System 100 K
The above restrictions are enforced by the CLI.
LIFs and bridge domains
A Layer 2 application for LIFs is for bridge domains (BDs). A BD is an infrastructure that supports the implementation of different switching technologies; it is essentially a generic broadcast/forwarding domain that is not tied to a specific transport technology. Bridge domains support a wide range of service endpoints, including regular Layer 2 endpoints and Layer 2 endpoints over Layer 3 technologies. Logical interfaces representing BD endpoints must be created before they can be bound to a BD. For more information and configuration details, refer to Bridge Domains.
The following are some common rules to consider in configuring logical interfaces:
If the interface is already configured as "switchport access," then it is not allowed to be configured with LIF. The reverse condition is also not allowed: the interface cannot be changed to mode access if a LIF is still configured under the main interface.
