TCAM profiles enable you to optimize TCAM resources according to your system requirements.
TCAM profiles other than default are supported only on Extreme 8820, SLX 9740, SLX 9640, and SLX 9540.TCAM is used by various forwarding applications. A TCAM profile supports a specified group of forwarding applications.
For Extreme 8820, SLX 9740, SLX 9640, and SLX 9540 devices, the following table displays maximum TCAM entries by features and TCAM profile.
* For shared limits, the TCAM is filled using first-come first-served.
** DB is shared with L2 and L3 control protocol features.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices, the following table displays maximum TCAM entries by features. The only TCAM profile supported is default.
** DB is shared with L2 ctrl protocol, L3 protocol, and so forth.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
| TCAM Profile | Feature | Default | IPv6 Optimised |
| INGRESS | Ingress L2 MAC ACLs | Supported | Supported |
| Ingress IPv4 ACLs (ACLs, PBR, RACL, RL, RACL-RL, v4Broadcast ACL) | Supported | Supported | |
| Ingress IPv6 ACLs (ACLs, PBR, RL, RACL, RACL-RL) | Supported | Supported | |
| VLL(PWE + VXLAN) | Supported | ||
| BUM RL, PORT RL, VLAN RL + BD RL | Supported | ||
| Tunnel | Supported | Supported | |
| App telemetry | Not Supported | Not Supported | |
| XC stat | Supported | Supported | |
| EGRESS | Egress Ipv6 acl | Not Supported | Supported |
| Egress L2 ACL (ACL, RL) | Supported | Supported | |
| Egress IPv4 ACL | Supported | Supported | |
For scale information, refer Scale and Standards Matrix document for this version.
