If you forgot the password for the VM root account and when shell prompt is available, you can recover the default password.
To perform the recovery process, you will need access to the shell prompt.
The shell prompt is only available in SLX 9540 when the platform is running version SLX-OS 20.1.x and below.
# reboot Press Esc during reboot. Hit ESC to stop autoboot: 0 FPGA f6000720 -> 0x12 1) Start system. 2) Recover password. 3) Enter command shell. Option?
Option? 3 =>
=> bootenv VM_Root_Recover RootPasswd =>
=> saveenv Saving Environment to SPI Flash... SF: Detected W25Q128BV @ 0:0 with page size 256 Bytes, erase size 64 KiB, 32 KiB, 4 KiB, total 16 MiB Erasing SPI flash...Writing to SPI flash... Erasing SPI flash...Writing to SPI flash...done =>
=> boot 6912784 bytes read in 152 ms (43.4 MiB/s) Valid Boot Flag Setup Size = 0x00004400 Magic signature found Using boot protocol version 2.0c Linux kernel version 3.14.17 (raop@hq1-ub-ecbld-373) #1 SMP Thu Jul 7 19:43:15 UTC 2016
fibranne
password.
