slxos_netdev_lag { 'name':
ensure => [present | absent],
active => [true | false],
lacp => [active | passive | disabled],
description => "vlag-description”,
minimum_links => minimum_links_value,
links => $lag_ports,
| Property | Description |
| name (required) | Specifies the name of the LAG. For example 10. |
| active (required) | Active configuration. By default, it is set to true. |
| lacp (optional) | Controls if and how the Link Aggregation Control Protocol (LACP) is used:
| description (optional) | Configures the VLAN description. |
| minimum_links (optional) | Specifies the number of physical links that must be in the “up” condition to declare the LAG port as being in the “up” condition. By default, this value is set to 0. |
| links (required) | Specifies a list of physical interfaces that compose the LAG bundle. |
The following Puppet code segment configures a LAG named 10 with several properties.
class node1 {
$ip23= "http://admin:password@10.11.12.13:830"
$lag_ports = ['eth 0/2', 'eth 0/3']
slxos_netdev_lag { '10':
#ensure => absent,
#description => "port-channel 10",
minimum_links => 5,
lacp => active,
Use the show port-channel command to verify the results of the code segment on the switch.
device# show port-channel 10 LACP Aggregator: Po 10 Aggregator type: Standard Ignore-split is enabled Admin Key: 0010 - Oper Key 0010 Partner System ID - 0x0000,00-00-00-00-00-00 Partner Oper Key 0000 Link: eth 1/2 (0x10C004000) sync: 0 Link: eth 1/3 (0x10C006000) sync: 0
