slxos_netdev_interface { "name":
admin => [up | down],
mtu => mtu_value,
speed => “speed_value”,
duplex => $target
target => $target
| Property | Description |
| name (required) | Specifies the name of the physical interface. |
| admin (optional) | Configures the interface as administratively enabled or disabled. By default, it is up. |
| mtu_value (optional) | Configures the interface maximum transmission unit (MTU) value. |
| speed_value (optional) | Configures the interface speed. Possible values are auto, 10m, 100m, 1g, and 10g.The default is auto. |
| duplex | Configures duplex mode: auto, full, or half. By default, it is set to auto. |
| target (optional) | Specifies device connection information. For example, http://admin:password@[3001::1]:830 NOTE: The target can also be specified by using a shortcut. An example is: $ip23= "http://admin:password@10.12.13.14:830; you can then use $ip23 subsequently. |
The following Puppet code segment configures several properties for the Ethernet interface.
class node1 {
$ip23= "http://admin:password@10.12.13.14:830"
slxos_netdev_interface { “eth-1/1":
ensure => present,
admin => up,
description => "this is a storage port",
mtu => 2200,
speed => "10000",
target => $ip23
Use the show running interface command to verify the results of the code segment on the switch.
device# sh run interface ethenet 1/1 interface ethernet 1/1 speed 10000 mtu 2200 description this is a storage port no shutdown !
