To create Router Interfaces for the tunnel endpoints:
To configure the Router Interface on one of the tunnel end points:
Enter global configuration mode.
SLX# configure terminal
SLX (config)#
Create the Router Interface. A Router Interface is a VE
interface.
SLX (config)# interface Ve 20
SLX (conf-if-Ve-20)#
To configure VRF support for this VE interface. Through this
configuration, VRF is supported on the GRE IPv4 tunnel. Here the VRF is
named red.
SLX (conf-if-Ve-20)# vrf forwarding red
Configure the OSPF for IPv4 traffic.
SLX (conf-if-Ve-20)# ip ospf area 1
You can also configure ISIS and BGP protocols.
Configure the OSPF for IPv6 traffic.
SLX (conf-if-Ve-20)# ipv6 ospf area 1
When configuring OSPFv3 for IPv6, ensure no ACLs are applied on this VE. This limitation is
applicable to SLX 9740 and Extreme 8820 devices only.
Configure the IPv4 address for the VE interface. This configuration
enables the transmission of IPv4 traffic through the GRE Tunnel.
SLX (conf-if-Ve-20)# ip address 23.23.23.1/24
Configure the IPv6 address for the VE interface. This configuration
enables the transmission of IPv6 traffic through the GRE Tunnel.
SLX (conf-if-Ve-20)# ipv6 address 2301:1::1:1/64
Exit out the VE interface configuration.
SLX (conf-if-Ve-20)# exit
SLX (config)#
To configure the Router Interface on the other tunnel end point:
SLX (config)#
interface.
SLX (config)# interface Ve 22
SLX (conf-if-Ve-22)#
named red.
SLX (conf-if-Ve-22)# vrf forwarding red
Configure the OSPF area to consolidate traffic from a single network.
This configures the OSPF area for IPv4 traffic.
SLX (conf-if-Ve-22)# ip ospf area 1
This configures the OSPF area for IPv6 traffic.
SLX (conf-if-Ve-22)# ipv6 ospf area 1
SLX (conf-if-Ve-22)# ip address 23.23.23.2/24
SLX (conf-if-Ve-22)# ipv6 address 2301:1::1:2/64
SLX (conf-if-Ve-22)# exit
SLX (config)#
The following is a consolidation of the configuration commands
executed to create the VE interface on one of the tunnel end points.
interface Ve 20
vrf forwarding vrf-red
ip ospf area 1
ipv6 ospf area 1
The following is a consolidation of the configuration commands executed
to create the VE interface on the other tunnel end point.
interface Ve 22
ip ospf area 1
ipv6 ospf area 1
