Extreme SLX-OS QoS and Traffic Management Configuration Guide, 20.6.3
> Traffic Management Counters and Statistics
Published November 15, 2024
Preface
About This Document
What's New in this Document
Supported Hardware
Traffic Policing
Traffic Policing Overview
Policy Maps
Traffic Policing Behaviors
Class Maps
Two-rate, three-color marker
Control Plane Policing
CoPP Rate Limiting
CoPP-related Commands
VLAN-based rate limiting
Receive ACL Rate Limiting
Egress ACL Rate Limiting
Configuring IPv4 Egress Rate Limiting
Configuring IPv6 Egress Rate Limiting
TTL 0/1 Rate Limiting
Subnet Trap Rate Limiting
Rate Limiting Scalability
Configuring traffic policing
Configuring a policy map
QoS overview
QoS on the SLX 9250, SLX 9150, Extreme 8520, and Extreme 8720
QoS Feature Support on SLX-OS Platforms
Congestion control
How WRED works
Applying WRED
Link Level Flow Control
Explicit Congestion Notification
Hardware Buffer Configuration for Lossless Traffic
Scheduling
Scheduling types
Multicast queue scheduling
Ingress QoS mutation
Egress QoS Mutation
QoS Mutation Maps
Configuring DSCP mappings
DSCP-to-Traffic Class Mappings
Configuring a DSCP-to-traffic class map
Applying a DSCP-to-traffic class map to an interface
Configuring a DSCP-to-traffic class and drop precedence map
Applying a DSCP-to-traffic class and drop precedence map to an interface
Limitations for DSCP-to-traffic class mappings
Configuring an Interface Level QoS Traffic Class
Configuring Traffic Class to DSCP Mappings
Applying a Traffic Class to DSCP Map to an Egress Interface
Configuring Interface level QoS Trust DSCP
Describes configuring Interface level QoS Remark DSCP
Configuring WRED
Enable Priority Flow Control
Configuring Hardware Buffer for Lossless Traffic
Displaying the RED Profile and dropped packets information for an interface
Configuring Explicit Congestion Notification
Configuring Enhanced Transmission Selection
LLDP TLVs for Enhanced Transmission Selection
Priority Flow Control Configuration TLV
Enhanced Transmission Selection (ETS) Recommendation TLV
Enhanced Transmission Selection (ETS) Configuration TLV
Link Aggregation TLV
Configuring scheduling
Flow-based QoS
Configuring a CoS Mutation map on SLX 9740 and Extreme 8820
Applying a CoS Mutation map to a SLX 9740 or Extreme 8820
