Applying a DSCP-to-traffic class and drop precedence map to an interface
A QoS DSCP-to-traffic class and drop precedence map has been configured
The ingress DSCP value can be used to classify traffic in to a specific traffic class and drop precedence by applying a DSCP-to-traffic class and drop precedence map on the ingress interface.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device(config)# interface ethernet 0/2
  3. Enable the QoS DSCP-to-traffic class and drop precedence map on the interface.
    device(conf-if-eth-0/2)# qos dscp-traffic-class dscpTcDpMap
  4. Return to privileged exec mode.
    device(conf-if-eth-0/2)# end
  5. Verify the configuration
    device# show qos maps dscp-traffic-class dscpTcDpMap
    DSCP-to-TC Map: dscpTc (x/y: TC = x, DP = y, DSCP = d1d2)
        d1 :  d2  0   1   2   3   4   5   6   7   8   9
         0 :     0/0 0/0 0/0 0/0 0/0 0/0 0/0 0/0 1/0 1/0
         1 :     1/0 1/0 1/0 1/0 1/0 1/0 2/0 2/0 2/0 2/0
         2 :     2/0 2/0 2/0 2/0 3/0 3/0 3/0 3/0 3/0 3/0
         3 :     3/0 3/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0
         4 :     5/0 5/0 5/0 5/0 5/0 5/0 5/0 5/0 6/0 6/0
         5 :     6/0 6/0 6/0 6/0 6/0 6/0 7/0 7/0 7/0 7/0
         6 :     7/0 7/0 7/0 7/0
        Enabled on the following interfaces: Eth 0/2
  6. Save the running-config file to the startup-config file.
Apply a QoS DSCP-to-traffic class map to an interface configuration example
