5420 Series Switch LEDs
ExtremeSwitching 5420 Series front panel port LEDs, as described in the following table:
Table 1. 5420 Series Port LEDs
LED
Color/State
Port State
SYStem status LED
(Legacy MGMT function)
Note: The system status LED is solid green to indicate normal operation when the switch is running Fabric Engine.
Green flash slowly
POST Passed,
normal operation, blinks on standalone switch, stack primary, and backup nodes in a stack;
off for standby nodes in a stack
Green blinking
POST in progress
Amber blinking
POST failed or overheat
PSU status LEDs P1/P2
Green
Power On
Off
Power off and no power attached
Amber Blinking
Power supply failures
Speed status (SPD), Stacking status (STK)SPD solid greenSpeed mode
STK solid greenStacking mode
All offNormal mode
Fan status for 5420F
Green
Normal operation
Amber Blinking
Fan failure
Fan module status for 5420M
Green
Normal operation
Amber Blinking
Fan module failure
Off
Fan module not present
Bluetooth Status LED (BT)
Green Blinking
Bluetooth pairing in progress
Green
Bluetooth connected
Off
Bluetooth not connected
Locator LED (LOC)
Blue Blinking
Locator function
The following figure shows the two alternate mode LEDs for 5420 Series switches: SPD and STK. The Mode button is used to cycle through three display modes for the port LEDs. In the default mode, SPD and STK are off. SPD and STK display modes expire after 30 seconds, at which time the port LEDs revert to the default SYS mode. Pressing and holding the the Mode button initiates Bluetooth pairing.
5420 Series Mode and System Status LEDs
Front panel view of LEDs and ports
Front-panel PoE ports use Amber to indicate PoE states.
Port LEDs in Default (SYS) Mode
In the default SYS mode, SPD is OFF, and the port status displays behavior for link, traffic, and PoE as described in the following table:
Table 2. Port LEDs in SYS Mode (default)
Color/State
Meaning
Green
Link is OK; port is not powered
Amber
Link is OK; port is powered; no traffic
Green blinking
Link is OK and transmitting packets; port is not powered
Amber blinking
Link is OK and transmitting packets; port is powered
Amber slow blinking
No link, or disabled port; port is powered
Alternating amber and green
Port has a power fault
Off
Port is not powered, has no link, or is disabled
Port LEDs in SPD Mode
The port LEDs enter the SPD display mode when the Mode button is pressed one time, indicated by the SPD LED. SPD mode is used to help determine the operational speed of a port.
There are two LEDs per SFP-DD port on 5420 models. When an SFP-DD port is used for Ethernet and stacking is disabled, each SFP-DD port can be used as either a single SFP+ port or two SFP+ ports if an SFP-DD transceiver is used on 5420M models. When the SFP-DD port is used for as a single SFP+ port, the first LED represents link and traffic, while the second LED is not operational. When the SFP-dd port is used as two SFP+ ports, the first LED represents link and traffic for the first port, and the second LED represents link and traffic for the second port. 5420F models are limited to one 10Gbps port per SFP-DD port in Ethernet mode with stacking disabled. The second SFP+ port is not available and the second LED is not operational.
In stack mode, each SFP-DD port can be used as one 20Gbps SFP+ port, or one 10Gbps SFP+ port, depending on the stack speed and optic used. The first LED represents the link state and traffic of the stack port with solid or blinking green. The second SFP+ port is not available and the second LED is not operational.
Color and blink pattern indicate speeds, as referenced by the following table:
Table 3. Port LEDs in SPD Mode
Color/State
Speed
Green
10Mbps
Green blinking
100Mbps
Amber
1000Mbps
Amber slow blinking
2.5Gbps
Green slow blinking
10Gbps
Green fast blinking
25Gbps
Green fast blinking
40/50Gbps
Port LEDs in STK Mode
The port LEDs enter the STK display mode after the Mode button is pressed twice, indicated by the STK LED. STK mode is used to indicate slot presence and slot number via the first eight port LED, as referenced by the following table:
Table 4. Port LEDs in STK Mode
Color/State
Speed
Green
The slot corresponding to the port number of the LED is present.
Green blinking
This slot has a slot number corresponding to the port number of the blinking LED.
Management Port LEDs
The management port uses two LEDs to indicate port activity and link status, as referenced by the following table:
Table 5. Management Port LEDs
Right side LED State
LinkGreenLink up
OffNo link up or port disabled
Left side LEDState
ActGreen blinkingPacket transmitting or receiving
OffNo packet transmitting or receiving
