When deploying a new stack, follow these recommendations for
configuring the software:
Plan to use the stack as if it were a single multi-slot switch.
You need to decide the number and type of stackable switches in the stack and how
the stack ports will be connected to the network.
You can physically connect the stack
to your networks before the nodes are configured. However, the default configuration
on a switch in non-stacking mode assumes a default untagged VLAN that contains all
switch ports. When first powered on, the switch acts as a Layer 2 switch, possibly
resulting in network loops.
Make sure all nodes support the
SummitStack feature and are running the same
Switch Engine software version. (See the
Switch Engine 32.1 Feature License Requirements
.) To
view the Switch Engine
software version on a node, restart the node and run the command:
show version {detail | processname | images {partitionpartition} {slotslot_number} }
If any node does not have the right version, install the
correct version on that node. Use the same image partition on all nodes. After
stacking is enabled, images can be upgraded from the stack only if the same
image is selected on all nodes.
If you intend to deploy new units
that might be part of a stack in the future, turn on stacking mode during initial
deployment to avoid the need for a future restart. The only disadvantages of
stacking mode are the loss of QoS (quality of service) profile QP7 and the
reservation of some of the packet buffer space for stacking control traffic.
You can configure the stack by
logging into the primary node or any of the other nodes.
If the primary-capable stackable
switches have different purchased license levels, you might need to configure
license level restrictions on some nodes before those nodes can join the stack. See
the
Switch Engine 32.1 User Guide
for more information
about managing licenses.
If the stack supports any feature
pack license (such as MPLS or Direct Attach), that feature pack license must be
installed on all primary-capable nodes to support that feature and to prevent
traffic interruption if a failover event occurs.
Most stacking specific configurations are effective only after a
restart. However, most non-stacking configuration commands take effect immediately
and require no restart.
A basic stack configuration can be achieved by using the Easy Setup procedure, as
described in the
If EAPS, Spanning Tree, or any Layer
2 redundancy protocol is not running on the network, make sure that your network
connections do not form a network loop.
