Replace a Fan Module
To replace the fan module in a switch, do the following:
  1. Completely loosen the captive retaining screws on the fan module.
    On most switch models, the fan module has two retaining screws at the bottom corners of the module, as shown in Removing a Fan Module.
    On some switch models, the fan module has a single retaining screw at the top right corner of the module.
  2. Slide the fan module out of the switch and set it aside.
    Removing fan module with arrow and unscrew direction
  3. Verify that the airflow direction on the replacement fan module matches that of the installed fan modules.
    Fans with front-to-back airflow are labeled Air Out. Fans with back-to-front airflow are labeled Air In.
  4. Carefully slide the replacement fan module into the switch.
    Installing a Fan Module
    Installing fan module with arrow and screw direction
  5. Align and fully tighten the captive retaining screws.
