Extreme 7520 Installation Guide
> General Safety Precautions
Extreme Networks, Inc. May 01, 2025
Introduction to the Extreme 7520 Installation Guide
New in this Guide
Extreme 7520 Overview
Extreme 7520-48Y-8C Switch Features
Extreme 7520-48YE-8CE Switch Features
Extreme 7520-48XT-6C Switch Features
Port Partitioning
Manage Your Switch
Universal Ethernet Ports
Secure Boot
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
800 W AC Power Supplies
800 W DC Power Supplies
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Log In for the First Time on Switch Engine
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove and Replace Components
Remove the Device from the Rack
Remove a Device from a Four-Post Rack
Remove a Device from a Two-Post Rack
Replace Internal Power Supplies
Airflow Direction Requirements
Replace an 800 W Internal AC Power Supply
Replace an 800 W Internal DC Power Supply
Replace Fan Modules
Replace a Fan Module
Monitor the Switch
System Status LEDs
RJ-45 Management Port LEDs
SFP+/SFP28 Port LEDs for 7520-48Y-8C and 7520-48YE-8CE
1G/10G RJ45 Port LEDs for the 7520-48XT-6C
QSFP28 Port LEDs
800 W AC Power Supply LEDs
800 W DC Power Supply LEDs
Technical Specifications
7520 Series Technical Specifications
Acoustic Noise and Fan Speed
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
Maintenance Safety
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
Regulatory Information
CE statement
EMC Warnings
China and Taiwan: Restriction of Hazardous Substances (ROHS)
Canadian requirements
China CCC statement
Australia (RCM)
Federal Communications Commission (FCC) Notice
Germany statement
KCC statement (Republic of Korea)
Japan (VCCI Class A)
Japan power cord
Follow these guidelines:
Do not try to lift objects that you think are too heavy for you.
When you install equipment in a rack, load heavier devices in the lower half of the rack first to avoid making the rack top-heavy.
Use only tools and equipment that are in perfect condition. Do not use equipment with visible damage.
Route cables in a manner that prevents possible damage to the cables and avoids causing accidents, such as tripping.
Do not place a monitor or other objects on top of the equipment. The chassis cover is not designed to support weight.
To reduce the risk of fire, use only #26 AWG or larger telecommunications line cord. Use only copper conductors.
Do not work on the system or connect or disconnect cables during periods of lightning activity.
This equipment must be grounded. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor.
