For switches with replaceable power supplies, refer to the following information to replace the power supplies. The switches have two power supply slots. In a switch with a redundant power configuration, you can replace one power supply without powering down the switch ("hot swapping"). Installed power supplies can be AC, DC, or a combination of AC and DC.
Images in this topic might show switches that are not identical to the ones you are using. However, the procedure for replacing an internal power supply is the same for all Extreme Networks switches.
Read all of the information in this chapter thoroughly before attempting to replace a power supply.To replace one or both AC internal power supplies in the switch, follow the steps in Replace an 800 W Internal AC Power Supply.
To replace one or both DC internal power supplies in the switch, follow the steps in Replace an 800 W Internal DC Power Supply.
Section contents:
