7830 Series Installation Guide
> Korea EMC Statement
Extreme Networks, Inc. February 01, 2026
Introduction to the 7830 Series Installation Guide
7830 Series Switch Features
Port Subdivisions
Manage Your Switch
Fans Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
2400 W AC Power Supplies
2400 W DC Power Supplies
Expansion Modules for Use with Your Switch
Versatile Interface Modules for the 7830 Series Switch
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Expansion Modules
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Log In for the First Time on Fabric Engine
Remove and Replace Components
Remove a Switch from a Rack
Remove a Device from a Four-Post Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Connect a DC Power Supply to the Source Voltage
Required Tools and Materials for Installing a DC Power Supply
Prepare the Cables for a DC Power Supply
Connect the Ground Wire to a DC Power Supply
Connect the Wires to the Source Voltage
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Replace Expansion Modules
Replace Versatile Interface Modules
Monitor the Switch
System Status LEDs
1G/10G SFP+ Management Port LED
100M/1G/10G RJ45 Management Port LEDs
QSFP28 Advanced Services Management Port LED
Port Status LEDs
Power Supply LEDs
Versatile Interface Module Port LEDs
Technical Specifications
7830 Series Technical Specifications
Acoustic Noise and Fan Speed
CPU/Memory
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
Korea EMC Statement
