Configure AP Details and Radio Settings
Use this procedure to modify settings for an access point (AP) and its radio properties.
  1. Go to Configure > Devices > Access Points.
  2. Select an AP from the list.
    Name
    Text field used to identify the AP.
    Hostname
    The Hostname for the AP. The Hostname value can be the same as or different from the AP Name. Both the AP Name and AP Hostname are displayed on the AP List and on the AP Details dialog. See Include Hostname in the Advanced Network Settings, to include the AP Hostname in the beacon signal.
    Description
    Optional description.
    Environment
    The operational environment of the AP. For Wi-Fi 7 APs, this setting is under the Professional Installation tab.
    Profile
    Select the profile link to jump to the configuration Profile associated with the selected AP. All Profile changes affect all APs associated with the Profile. To override configuration settings for a specific AP, select Advanced > Overrides for the selected AP.
  3. To take action on the selected AP, select the Actions button.
  4. Configure the following radio properties:
    The AP must be part of a device group before the radio settings and the Professional Install button are displayed. To add an AP to a device group, see Add APs.
    Table 1. Radio Properties
    FieldDescription
    RadiosThe Radios banner displays the AP's supported radio bands, and if a radio is configured as Mesh, Client Bridge, or Sensor, it is indicated.
    Note: Mesh and Client Bridge cannot be configured on the same AP.
    Use RF Management PolicyChoose whether to assign the RF Management policy that is associated with the device group to the radio, or to manually configure a channel plan, as follows:
    • Select Yes to use the Smart RF policy. Use the links to the RF Management Policy and the Site configuration GUIs that are provided to edit related settings.
    • Select Fixed Channel to manually set a channel width and configure a channel plan. You can modify an existing Fixed Channel radio setting and channel plan here.
    To modify an RF Management Policy, go to Advanced > Overrides.
    Mesh — Mesh Radio configuration supports Fixed Channel for root APs and Mesh ACS for non-root APs. See Configure a Meshpoint Network for more information about configuring a Mesh Network.
    Channel WidthDetermines the channel width for the radio. Valid values are:
    • 20 MHz
    • 40 MHz
    • 80 MHz (supported on 5GHz only 802.11ac and 802.11ax)
    • 160 MHz
      • AP5xx — Radio 1 and Radio 2 support 160 MHz
      • AP4xx / AP4xxC — Radio 2 only (5 GHz band) supports 160 MHz
      • AP3020W — Radio 1 (6 GHz band) and Radio 2 (5 GHz band) support 160 MHz
      • AP4000/ AP4000-1 — Radio 2 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP4020/X/FX — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP4060/X — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP5010 — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP5020 — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP5022/FX/SD6 — Radio 1 (5 GHz and 6 GHz bands), Radio 2 (5 GHz band), and Radio 3 (6 GHz band) support 160 MHz
      • AP5050 — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz (Radio 3 is currently turned off for regulatory compliance.)
      • AP5060D/U — Radio 1 (5 GHz band) and Radio 3 (6 GHz band) support 160 MHz
      • AP3xx/AP3xxC — Do not support 160 MHz width on the 5 GHz radio
      Note: A best practice is to use a predetermined width configured as part of the design of the entire RF deployment. To learn about how Smart RF handles channel width settings, see Understanding Smart RF and Channel Width.
    • 320 MHz — AP3020W, AP4020/X/FX, AP5020, AP5022/FX/SD6, and AP5060D/U support 320 MHz in radio mode ax6be. 320 MHz is not supported in radio mode ax6, or when there are no available channels due to compliance configuration.
      Note: Smart RF is currently not supported for 320 MHz.
    Select to select a channel.
    Request New ChannelSpecifies the primary channel of the wireless AP. Depending on the licensed regulatory domain, channels may be restricted. ACS in the 2.4 GHz radio band with 40 MHz channels is not recommended due to severe co-channel interference.
    Max Tx Power Determines the maximum power level that can be used by the radio in dBm. The values are governed by compliance requirements based on the country, radio, and antenna selected, and vary with AP model type.
    Fallback Channel(s)
    You can configure the fallback channel in case the main channel is unavailable. The system logs when APs are operating with the fallback channel so that administrators are aware the primary channel is not in use.
    First, hover the mouse pointer over the information icon to see if it is DFS (5 GHz) or AFC (6 GHz). Then, refer to the sections below, depending on which one it is:
    For Dynamic Frequency Selection (DFS):
    Specify a 5GHz channel that the radio will adopt if DFS fails. ExtremeWireless APs support up to 9 channels.
    The following setting is supported on ExtremeWireless AP models that use Wi-Fi 6 or higher standards and are configured for a Centralized site.
    Note: DFS is not recommended on a radio configured for Mesh.
    • Return to configured channel after failed event. When selected, the device returns to the configured radio channel after a DFS failed event. When this option is enabled, the following options display:
      • DFS Revert Hold Time. The amount of time that a device will stay on a fallback channel before returning to the selected DFS channel. Valid values are 30 to 3600 minutes. The default value is 90 minutes.
      • DFS Revert Client Aware. A threshold that determines if the radio will revert back to the DFS channel after moving to the configured channel. In addition to DFS Revert Hold Time, the radio client count also has to drop below the configured threshold.
        If the number of clients using the radio channel is less than the configured threshold, the radio will revert to the DFS channel. Valid values are 1 – 255. The default value is 0. Zero indicates that the conditioning based on number of clients is ignored.
    For Automatic Frequency Coordination (AFC):
    You can configure the fallback channel in case the main channel is removed by the AFC server. Only one AFC Fallback Channel can be selected at at time.
    Specify a 6GHz backup channel that the radio will adopt if AFC fails.
    If the primary channel becomes available again, the AP returns to the primary channel.
    If the backup channel is also unavailable, then the AP transitions to "RADIO OFF due to compliance."
  5. Select Save.
