Simple Network Management Protocol (SNMP) is a standard that uses a common software agent to remotely monitor and set network configuration and runtime parameters. SNMP operates in a multi-vendor environment, and the agent uses MIBs (Management Information Base), which define what information is available from any manageable network device. You can also set traps using SNMP, which send notifications of network events to the system log.
ExtremeCloud IQ Controller offers SNMP configuration for the full appliance or configuration for switches associated with a specific site.
To configure SNMP for the full ExtremeCloud IQ Controller environment, go to Administration > System, then select the Settings tab.
To configure SNMP for the switches associated with a site, go to Configure > Sites and select a site. Then, select the Advanced tab.
