Trial Licenses for non-Universal Hardware Switches
For non-Universal Hardware switches, you can obtain a trial license, which enables you to use the license for 30 days, and you can downgrade trial licenses to a lower software license level during the trial period. You can extend the time of the trial by 30 days two times (for a total of 90 days). Most feature licenses are enabled. After you enable the trial license, the switch behaves as if all software license levels and feature licenses are enabled. The trial license key contains all the necessary information on the license level and the number of days. Trial licenses can be applied only once for each software version; if you upgrade to a different software version, you can reapply your trial license. It is not recommended to use a trial license in production.
The Network Timing feature license is not included in the trial license.
To enable a trial license, issue the command debug epm enable trial-license.
To clear a trial license, issue the command debug epm clear trial-license. A reboot is required before the clear license takes effect.
Enabling a newly obtained license requires clearing the trial license, and then rebooting the switch.
