The Value Edge License includes features for L2 switching and L3 routing.
The X435 is the only switch that supports the Value Edge license level, and can not be upgraded to any of the other license levels.The following table lists the features included in the Value Edge License.
Listed platforms that do not support the Value Edge license do support these features with a higher license level.| software feature | Supported platforms |
| EDP | All platforms |
| Fabric Attach | All platforms |
| Identity Management | All platforms |
| LLDP 802.1ab | All platforms |
| LLDP-MED extensions | All platforms |
| VLANs—Port based and tagged trunks | All platforms |
| VLANs—MAC-based | All platforms |
| VLANs—Protocol-based | All platforms |
| VLANs—Private VLANs | All platforms |
| VLANs—VLAN translation | All platforms |
| VMANs—Q-in-Q tunneling (IEEE 802.1ad VMAN tunneling standard) | All platforms |
| VMANs—Egress queue selection based on 802.1p value in S‑tag | All platforms |
| VMANs—Egress queue selection based on 802.1p value in C‑tag | All platforms |
| VMANs—Secondary ethertype support | All platforms |
| VMAN Customer Edge Port (CEP—also known as Selective Q-in-Q) | All platforms |
| VMAN Customer Edge Port CVID Egress Filtering / CVID Translation | All platforms |
| VMAN—CNP port | All platforms |
| VMAN—CNP port, double tag support | All platforms |
| VMAN—CNP port, double tag with egress filtering | All platforms |
| L2 Ping / Traceroute 802.1ag | All platforms |
| Jumbo frames (including all related items, MTU disc. IP frag.) | All platforms |
| QoS—egress port rate shaping/limiting | All platforms |
| QoS—egress queue rate shaping/limiting | All platforms |
| Link Aggregation Groups (LAG), static 802.3ad | All platforms |
| LAG dynamic (802.3ad LACP) edge, to servers only | All platforms |
| LAG (802.3ad LACP) core, between switches | All platforms |
| Port loopback detection and shutdown (ELRP CLI) | All platforms |
| Software redundant port | All platforms |
| STP 802.1D | All platforms |
| STP EMISTP +, PVST+ Compatibility mode (1 domain per port) | All platforms |
| STP EMISTP, PVST+ Full (multi-domain support) | All platforms |
| STP 802.1s | All platforms |
| STP 802.1w | All platforms |
| ERPS (4 max rings with matching ring ports) | All platforms |
| ESRP aware | All platforms |
| EAPS edge (4 max domains with matching ring
                                    ports) Note: You
                                    can increase the number of domains by upgrading to the Advanced
                                    Edge license (see Advanced Edge License Features).
                            All platforms |
| Link Fault Signaling (LFS) | All platforms |
| ELSM (Extreme Link Status Monitoring) | All platforms |
ACLs, applied on ingress ports
                            All platforms |
                            All platforms |
| ACLs, applied on egress ports | All platforms |
| ACLs, ingress meters | All platforms |
| ACLs, egress meters | All platforms |
ACLs
                            All platforms |
| CPU DoS protect | All platforms |
| CPU Monitoring | All platforms |
| SNMPv3 | All platforms |
| SSH2 server | All platforms |
| SSH2 client | All platforms |
| SCP/SFTP client | All platforms |
| SCP/SFTP server | All platforms |
| RADIUS and TACACS+ per command authentication | All platforms |
 Network Login
                            All platforms |
| Network Login—Multiple supplicants - multiple VLANs | All platforms |
| Trusted OUI | All platforms |
                                 MAC security
                            All platforms |
| IP security—DHCP Option 82—L2 mode | All platforms |
| IP security—DHCP Option 82—L2 mode VLAN ID | All platforms |
| IP security—DHCP IP lockdown | All platforms |
| IP security—Trusted DHCP server ports | All platforms |
| Static IGMP membership, IGMP filters | All platforms |
| IPv4 unicast L2 switching | All platforms |
| IPv4 multicast L2 switching | All platforms |
| IPv4 directed broadcast | All platforms |
                                 IPv4
                            All platforms |
| IPv6 unicast L2 switching | All platforms |
| IPv6 multicast L2 switching | All platforms |
| IPv6 netTools—Ping, traceroute, BOOTP relay, DHCP, DNS, and SNTP | All platforms |
| IPv4 netTools—Ping, traceroute, BOOTP relay, DHCP, DNS, NTP, and SNTP | All platforms |
| IGMP v1/v2 snooping | All platforms |
| IGMP v3 snooping | All platforms |
| Multicast VLAN Registration (MVR) | All platforms |
| Static MLD membership, MLD filters | All platforms |
| MLD v1 snooping | All platforms |
| MLD v2 snooping | All platforms |
| sFlow accounting | All platforms |
| CLI scripting | All platforms |
| Web-based device management | All platforms |
| Web-based management—HTTPS/SSL support | All platforms |
| XML APIs (for partner integration) | All platforms |
| MIBs - Entity, for inventory | All platforms |
| Connectivity Fault Management (CFM) | All platforms |
| Remote mirroring | All platforms |
| Egress mirroring | All platforms |
| Y.1731 compliant frame delay and delay variance measurement | All platforms |
| MVRP - VLAN Topology Management | All platforms |
| EFM OAM - Unidirectional Link Fault Management | All platforms |
| Universal Port—VoIP auto configuration | All platforms |
| Universal Port—Dynamic user-based security policies | All platforms |
| Universal Port—Time-of-day policies | All platforms |
