Ensure that you have the correct license installed on the switch (for more information about licenses, see the
ExtremeXOS v33.3.1 Licensing Guide
), and that you have purchased a
Solid State Storage Device (SSD) SSD-120.
To set up an Integrated Application Hosting (IAH) guest virtual machine (VM):
- Install the Solid State Storage Device (SSD) SSD-120:
- Power down the switch.
- On the rear panel of the switch, remove the cover from the SSD
slot.
- Insert SSD-120 into the SSD slot.
- Power up the switch.
- Download a VM
installation file (OVA, qcow2, or any QEMU-compatible file) to SSD-120 to
/usr/local/vm/packages using the command scp2 {cipher
cipher} {mac
mac} {compression [on | off]} {port
portnum} {vr
vr_name} user [hostname | ipaddress]:remote_file
local_file
. Alternatively, you can use
the Third-Party Virtual Machine (TPVM), which is included on SSD-120.
- Install the VM using one of the
following commands:
- Disk image:
create vm
vm_name
image_file {memory
memory_size} {cpus
num_cpus} {slot
slot_ID}{vnc [none | vnc_display]}
- OVA file:
create vm
vm_name
ova
ova_file {memory
memory_size} {cpus
num_cpus} {slot
slot_ID} {vnc [none | vnc_display]}
Compatibility
issues might occur when using third-party OVA files. The image format
qcow2 is generally more reliable.
The default for number of CPUs allocated is 1. The default amount of RAM
allocated to a VM is 4,096 MB. You can change this with the create vm command
as needed.
The VNC server only listens to the switch‘s loopback IP address
(127.0.0.1). You need to forward TCP traffic from the server‘s port on the
switch to a port that the client software is running on using an
SSH tunnel. On the switch, VNC port numbers
range from 5,900 to 5,915.
To create this setup, use the following command:
ssh
admin@mgmt_ip -L port_on_client_system:127.0.0.1:port_on_switch
- Add IAH dedicated ports to the
VM.
configure vm
vm_name {add | delete} ports
portlist
- Choose whether or not the VM
should start up automatically when ExtremeXOS starts.
Automatic start-up is disabled by default. To enable automatic start-up, use the
following command:
enable vm
vm_name
autostart
- To open a session to the VM's
serial console, use the following command:
open vm
vm_name {console}
TPVM is configured to use a
serial console.
You cannot access the serial console before
starting a VM. You must start the VM, and then reboot it to gain serial
console access.
- Optionally, add virtual interfaces to the VM using the following command
(maximum 16 virtual interfaces):
configure vm
vm_name
add
virtual-interface
port
port {vlan
vlan_id} {name
vf_name}
- Optionally, change the vm's disk bus or controller, using the following
command:
configure vm
vm_name
disk
bus-type
bus_typeThe default bus type is VirtIO, but some operating systems are do not
support this, and as a consequence, the VM will fail to boot. You can
configure the bus type to IDE or SCSI.
- Start the VM.
start vm
vm_name
To check the status of the VM, use the following commands:
- For operational status information: show vm {vm_name | detail}
- For interfaces information: show vm
vm_name
guest
interfaces
If needed to save disk space, after successful creation of the VM, you can delete the
VM package file at /usr/local/vm/packages.
For additional IAH commands, see Integrated Application Hosting (IAH) Commands.
