X440-G2, X450-G2, and X460-G2 are not supported in this version.| Metric | Product | Limit |
| BGP auto-peering—maximum number of auto-peering nodes and VTEPs. | ExtremeSwitching, X465, X695 | 64 |
| BGP auto-peering attached IPv4 hosts— maximum number of attached IPv4 hosts. | ExtremeSwitching, X465, X695 | 64,000 |
| BGP auto-peering attached IPv6 hosts— maximum number of attached IPv6 hosts. | ExtremeSwitching, X465, X695 | 8,000 |
| BGP
auto-peering ECMP—maximum number of equal cost multipath for
auto-peering. Note: * Subject to the limitation imposed by the number of
physical ports on a switch.
| ExtremeSwitching, X465, X695 | 16* |
| BGP auto-peering maximum IPv4 prefixes with ECMP—Maximum number of IPv4 Network prefixes with ECMP. | ExtremeSwitching, X465, X695 | 64,000 |
| BGP auto-peering maximum IPv6 prefixes with ECMP—Maximum number of IPv6 Network prefixes with ECMP. | ExtremeSwitching, X465, X695 | 8,000 |
| BGP auto-peering MLAG peers—maximum MLAG peers per AutoBGP node. | ExtremeSwitching, X465, X695 | 1 |
| BGP auto-peering VRFs—maximum number of VRFs. | ExtremeSwitching, X465, X695 | 64 |
| BGP auto-peering EVPN instances—maximum EVPN instances. | ExtremeSwitching, X465, X695 | 1,024 |
| EAPS domains—maximum number of EAPS domains. Note: An EAPS ring that is being spatially reused cannot have
more than four configured EAPS domains.
| ExtremeSwitching, X465, X695 | 128 |
| EAPSv2 protected VLANs—maximum number of protected VLANs. | ExtremeSwitching, X465, X695 | 2,000 |
| ERPS domains—maximum number of ERPS domains without CFM configured. | ExtremeSwitching, X465, X695 | 32 |
| ERPS domains—maximum number of ERPS domains with CFM configured. | ExtremeSwitching, X465, X695 | 32 |
| ERPSv1 protected VLANs—maximum number of protected VLANs. | ExtremeSwitching, X465, X695 | 2,000 |
| ERPSv2 protected VLANs—maximum number of protected VLANs. | ExtremeSwitching, X465, X695 | 2,000 |
| ESRP groups—maximum number of ESRP groups | ExtremeSwitching X465, X695 | 32 |
| ESRP domains—maximum number of ESRP domains. | ExtremeSwitching, X465, X695 | 64 |
| ESRP L2 VLANs—maximum number of ESRP VLANs without an IP address configured. | ExtremeSwitching, X465, X695 | 1,000 |
| ESRP L3 VLANs—maximum number of ESRP VLANs with an IP address configured. | ExtremeSwitching, X465, X695 | 511 |
| ESRP (maximum ping tracks)—maximum number of ping tracks per VLAN. | ExtremeSwitching, X465, X695 | 8 |
| ESRP (IP route tracks)—maximum IP route tracks per VLAN. | ExtremeSwitching, X465, X695 | 8 |
| ESRP (VLAN tracks)—maximum number of VLAN tracks per VLAN. | ExtremeSwitching, X465, X695 | 1 |
| L2 VPN: VCCV (pseudowire Virtual Circuit Connectivity Verification) VPNs per switch—maximum number of VCCV enabled VPLS VPNs. | ExtremeSwitching, X465, X695 | 16 |
| L2 VPN: VPLS MAC addresses—maximum number of MAC addresses learned by a switch. | ExtremeSwitching, X465, X695 | 140,000 |
| L2 VPN: VPLS VPNs—maximum number of VPLS virtual private networks per switch. | ExtremeSwitching, X465, X695 | 1,023 |
| L2 VPN: VPLS peers—maximum number of VPLS peers per VPLS instance. | ExtremeSwitching, X465, X695 | 64 |
| L2 VPN: LDP pseudowires—maximum number of pseudowires per switch. | ExtremeSwitching, X465, X695 | 7,000 |
| L2 VPN: static pseudowires—maximum number of static pseudowires per switch. | ExtremeSwitching, X465, X695 | 7,000 |
| L2 VPN: Virtual Private Wire Service (VPWS) VPNs—maximum number of virtual private networks per switch. | ExtremeSwitching, X465, X695 | 4,090 |
| MPLS RSVP-TE interfaces—maximum number of interfaces. | ExtremeSwitching X465, X695 | 32 |
| MPLS RSVP-TE ingress LSPs—maximum number of ingress LSPs. | ExtremeSwitching X465, X695 | 2,000 |
| MPLS RSVP-TE egress LSPs—maximum number of egress LSPs. | ExtremeSwitching X465, X695 | 2,000 |
| MPLS RSVP-TE transit LSPs—maximum number of transit LSPs. | ExtremeSwitching, X465, X695 | 4,000 |
| MPLS RSVP-TE paths—maximum number of paths. | ExtremeSwitching, X465, X695 | 2,000 |
| MPLS RSVP-TE profiles—maximum number of profiles. | ExtremeSwitching X465, X695 | 2,000 |
| MPLS RSVP-TE EROs—maximum number of EROs per path. | ExtremeSwitching X465, X695 | 64 |
| MPLS LDP peers—maximum number of MPLS LDP peers per switch. | ExtremeSwitching X465, X695 | 128 |
| MPLS LDP adjacencies—maximum number of MPLS LDP adjacencies per switch. | ExtremeSwitching X465, X695 | 64 |
| MPLS LDP ingress LSPs—maximum number of MPLS LSPs that can originate from a switch. | ExtremeSwitching X465, X695 | 2,048 |
| MPLS LDP-enabled interfaces—maximum number of MPLS LDP configured interfaces per switch. | ExtremeSwitching X465, X695 | 128 |
| MPLS LDP transit LSPs—maximum number of MPLS transit LSPs per switch. | ExtremeSwitching X465, X695 | 4,000 |
| MPLS LDP egress LSPs—maximum number of MPLS egress LSPs that can terminate on a switch. | ExtremeSwitching X465, X695 | 4,000 |
| MPLS static egress LSPs—maximum number of static egress LSPs. | ExtremeSwitching, X465, X695 | 8,000 |
| MPLS static ingress LSPs—maximum number of static ingress LSPs. | ExtremeSwitching X465, X695 | 4,000 |
| MPLS static transit LSPs—maximum number of static transit LSPs | ExtremeSwitching X465, X695 | 4,000 |
| OSPFv2/v3 ECMP—maximum number of equal cost multipath OSPFv2 and OSPFv3. | ExtremeSwitching, X465, X695 | 64 |
| OSPFv2 areas—as an ABR, how many OSPF areas are supported within the same switch. | ExtremeSwitching, X465, X695 | 8 |
| OSPFv2 external routes—recommended maximum number of external routes contained in an OSPF LSDB. | ExtremeSwitching, X465, X695 | 10,000 |
| OSPFv2 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes contained in an OSPF LSDB with one ABR in OSPF domain. | ExtremeSwitching, X465, X695 | 2,000 |
| OSPFv2 inter-vr or leaking routes—recommended maximum number of inter-vr routes contained in an OSPF LSDB. | ExtremeSwitching, X465, X695 | 2,000 |
| OSPFv2 interfaces—recommended maximum number of OSPF interfaces on a switch (active interfaces only). | ExtremeSwitching, X465, X695 | 4 |
| OSPFv2 links—maximum number of links in the router LSA. | ExtremeSwitching, X465, X695 | 400 |
| OSPFv2 neighbors—maximum number of supported OSPF adjacencies. | ExtremeSwitching, X465, X695 | 4 |
| OSPFv2 routers in a single area—recommended maximum number of routers in a single OSPF area. | ExtremeSwitching, X465, X695 | 100 |
| OSPFv2 virtual links—maximum number of supported OSPF virtual links. | ExtremeSwitching, X465, X695 | 32 |
| OSPFv3 areas—as an ABR, the maximum number of supported OSPFv3 areas. | ExtremeSwitching, X465, X695 | 100 |
| OSPFv3 external routes—recommended maximum number of external routes. | ExtremeSwitching, X465, X695 | 10,000 |
| OSPFv3 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes. | ExtremeSwitching, X465, X695 | 4.000 |
| OSPFv3 interfaces—maximum number of OSPFv3 interfaces (active interfaces only). | ExtremeSwitching, X465, X695 | 4 |
| OSPFv3 neighbors—maximum number of OSPFv3 neighbors. | ExtremeSwitching, X465, X695 | 4 |
| OSPFv3 virtual links—maximum number of OSPFv3 virtual links supported. | ExtremeSwitching, X465, X695 | 16 |
| PIM IPv4 (maximum interfaces)—maximum number of PIM active interfaces. | ExtremeSwitching, X465, X695 | 4 |
| PIM IPv4 Limits—maximum number of multicast groups per dynamic rendezvous point. | ExtremeSwitching, X465, X695 | 180 |
| PIM IPv4 Limits—maximum number of multicast groups per static rendezvous point. | ExtremeSwitching, X465, X695 | 3,000 (depends on policy file limits) |
| PIM IPv4 Limits—maximum number of multicast sources per group. | ExtremeSwitching, X465, X695 | 5,000 |
| PIM IPv4 Limits—maximum number of dynamic rendezvous points per multicast group. | ExtremeSwitching, X465, X695 | 145 |
| PIM IPv4 Limits—static rendezvous points. | ExtremeSwitching, X465, X695 | 32 |
| PIM IPv6 (maximum interfaces)—maximum number of PIM active interfaces. | ExtremeSwitching, X465, X695 | 4 |
| PIM IPv6 Limits—maximum number of multicast sources per group. | ExtremeSwitching, X465, X695 | 1,750 |
| PIM IPv6 Limits—maximum number of multicast groups per dynamic rendezvous point. | ExtremeSwitching, X465, X695 |
70 |
| PIM IPv6 Limits—maximum number of multicast groups per static rendezvous point. | ExtremeSwitching, X465, X695 |
| PIM IPv6 Limits—maximum number of dynamic rendezvous points per multicast group. | ExtremeSwitching, X465, X695 | 64 |
| PIM IPv6 Limits—maximum number of secondary addresses per interface. | ExtremeSwitching, X465, X695 | 70 |
| PIM IPv6 Limits—static rendezvous points. | ExtremeSwitching, X465, X695 | 32 |
| Port-specific VLAN tags—maximum number of port-specific VLAN tags. | ExtremeSwitching, X465 | 1,023 |
| ExtremeSwitching, X695 | N/A | |
| Port-specific VLAN tags—maximum number of port-specific VLAN tag ports. | ExtremeSwitching, X465 | 4,000 |
| VLAN Port Interfaces (VPIF)—maximum number of VLAN port interfaces. | ExtremeSwitching X465, X695 | 131,585 |
| VRRP (v2/v3-IPv4)
(maximum instances)—maximum number of VRRP instances for a
single switch, with Advanced Edge license or higher. Note: These limits are applicable for Fabric Routing
configuration also.
Note: Number of groups configured should not
exceed the number of individual VRs supported (that is, in normal mode) for that platform
type.
| Normal Mode (as individual VRs): | |
| ExtremeSwitching, X465, X695 | 511 | |
| Scaled Mode (with groups): | ||
2,048 | |
| VRRP (v3-IPv6) (maximum instances)—maximum number of VRRP
instances for a single switch, with Advanced Edge or Base license,
or higher. (VRRP-VRRPv3-IPv6) Note: These limits are applicable for Fabric Routing
configuration also.
type.
| ExtremeSwitching X465, X695 | 511 | |
2,048 | |
| VRRP (v2/v3-IPv4/IPv6) (maximum VRID)—maximum number of unique VRID numbers per switch. | ExtremeSwitching X465, X695 Note: With Advanced Edge license or higher.
255 |
| VRRP (v2/v3-IPv4/IPv6) (maximum VRIDs per VLAN)—maximum number of VRIDs per VLAN. | ExtremeSwitching X465, X695 Note: With Advanced Edge license or higher.
255 |
| VRRP (v2/v3-IPv4/IPv6) (maximum ping tracks)—maximum number of ping tracks per VLAN. | ExtremeSwitching X465, X695 Note: With Advanced Edge license or higher.
8 |
| VRRP (maximum ping tracks)—maximum number of ping tracks per VRRP Instance under 128 VRRP instances, with Advanced Edge license or higher. | ExtremeSwitching X465, X695 | 8 (20 centisecond or 1 second hello interval) |
| VRRP (v3-IPv6) (maximum ping tracks)—maximum number of ping tracks per VRRP Instance under 128 VRRP instances, with Advanced Edge license or higher. | ExtremeSwitching X465, X695 | 8 (20 centisecond or 1 second hello interval) |
| VRRP (v2/v3-IPv4/IPv6) (maximum iproute tracks)—maximum number of IP route tracks per VLAN. | ExtremeSwitching, X465, X695 | 8 |
| VRRP (v2/v3-IPv4/IPv6)—maximum number of VLAN tracks per VLAN. | ExtremeSwitching X465, X695 | 8 |
| VXLAN—maximum virtual networks. Note: Every VPLS instance/PSTag VLAN reduces this limit by
1.
Note: Assumption is all BUM
(broadcast/unknown-unicast/multicast) FDB entries are pointing to the same set of RTEPs when
all VNETs use explicit flooding. Depends on whether all VNETs use standard or explicit and the
number of tenant VLAN ports.
| ExtremeSwitchingX465, X695 | 2,048–4,000 |
| VXLAN—maximum tenant VLANs plus port combinations Note: Every (VPLS/PSTag VLAN) + port reduces the limit by
1.
| ExtremeSwitchingX465, X695 | 4,096 |
| VXLAN—maximum static MAC to IP bindings. Note: Every FDB entry configured reduces this limit by 1.
| ExtremeSwitchingX465, X695 | 64,000 |
| VXLAN—maximum RTEP IP addresses | ExtremeSwitchingX465, X695 | 512 |
| VXLAN—maximum virtual networks with dynamic learning and OSPF extensions for VXLAN | ExtremeSwitchingX465, X695 | 4,000 |
| VXLAN—or replicator role, maximum number of attached leafs per switch. | ExtremeSwitching X465, X695 | 256 |
